POV-Ray : Newsgroups : povray.beta-test : HF_Square Parse Error Server Time
7 Mar 2026 09:05:47 EST (-0500)
  HF_Square Parse Error (Message 1 to 3 of 3)
Subject: HF_Square Parse Error
Date: 2 Oct 2001 10:18:03
Message: <3BB9CC2D.6EC9FA92@ewetel.net>
Hello :-))
Shapes.inc again. Trying to have a look at
    object {
      HF_Square(
        "f_noise3d(x*3, y*3, z*3)", // FunctionName
        <-4,0,1>, // MnExt
        < 4,1,4>, // MxExt
        <10,10>, // Res
        false, // Smooth
        "" // FileName
      pigment { Yellow }
I received this error:
Parse Error: Expected 'operator', ( found instead
in parse_string.tmp.
I think the code above should be valid... If not,
please forgive me, take my excuse and forget
about it.
By modifying the HF_Square macro a bit
#macro HF_Square(FunctionName, MnExt, MxExt, Res, Smooth, FileName)
 //#local Function =
Parse_String(concat("function(x,y,z){",FunctionName,"(x,y,z)}"))
   #local Function =
Parse_String(concat("function(x,y,z){",FunctionName,"}"))
I got it running...
Did I make any mistakes with the function declaration in
the code snippet above?
Greetings :-))
Thorsten
(3.5beta4, various systems, windows)
Subject: Re: HF_Square Parse Error
Date: 2 Oct 2001 11:21:52
Message: <3bb9db90@news.povray.org>
"Thorsten" <tho### [at] ewetelnet> wrote in message
news:3BB9CC2D.6EC9FA92@ewetel.net...
>     object {
>       HF_Square(
>         <-4,0,1>, // MnExt
>         < 4,1,4>, // MxExt
>         <10,10>, // Res
>         false, // Smooth
>         "" // FileName
>       pigment { Yellow }
> about it.
Although it's not said what is valid for use as "function" it seems to me to
be only those which don't require parameters.  For instance f_bozo and
f_crackle from the functions.inc.  I don't have any idea what the correct
way of using these is myself, only that those can work okay without
modification.
>  //#local Function =
>    #local Function =
> I got it running...
> Greetings :-))
> Thorsten
Date: 3 Oct 2001 00:54:09
Message: <3BBA997E.FF2190E3@ewetel.net>
> modification.
> >  //#local Function =
> >    #local Function =
An additional boolean parameter might come handy...
#macro HF_Square(FunctionName, MnExt, MxExt, Res, Smooth, FileName, Parameters)
#if (Parameters)
  #local Function = ... Version1
#else
  #local Function = ... Version2
Thank you :-))
Thorsten
