POV-Ray : Newsgroups : povray.beta-test : JPEG question Server Time
19 May 2026 03:35:17 EDT (-0400)
  JPEG question (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: JPEG question
Date: 26 Sep 2001 10:36:03
Message: <slrn9r3puk.9dp.ron.parker@fwi.com>
On Wed, 26 Sep 2001 10:17:56 -0400, Thorsten Froehlich wrote:
>In article <3BB1D33F.2C19078A@twoalpha.net> , Dean <dea### [at] twoalphanet>
>wrote:
>> I think the Adobe Photoshop JPG that it was originally, was
>> made to load 'fast' and not accurate.
>Yes, it is very possible that the problem is the "load fast", which probably
>implies it is the progressive encoding version (i.e. when you download a
>picture you first would see a low quality version that gets better as the
>download progresses).
Progressive encoding isn't marker type 0xDB, though.  Here's what the JPEG
FAQ has to say about various Photoshop incompatibilities:
  Old decoders that don't handle progressive JPEG will often give rather
  cryptic error messages when fed a progressive JPEG.  If you get a complaint
  like "Unsupported marker type 0xC2", then you definitely have a progressive
  JPEG file and a non-progressive-capable decoder.  (See part 2 of this FAQ
  for information about more up-to-date programs.)  Or you may get a generic
  error message that claims the file is corrupted or isn't JPEG at all.
  Adobe Photoshop and some other prepress-oriented applications will produce
  four-channel CMYK JPEG files when asked to save a JPEG from CMYK image mode.
  Hardly anything that's not prepress-savvy will cope with CMYK JPEGs (or any
  other CMYK format for that matter).  When making JPEGs for Web use, be sure
  to save from RGB or grayscale mode.
  Photoshop also has a habit of stuffing a rather large thumbnail/preview
  image into an application-private segment of JPEG files.  Some other
  applications (notably early releases of Sun's Java library) are known to
  choke on this data.  This is definitely a bug in those other applications,
  but the best available workaround is still to tell Photoshop not to save
  a thumbnail.  If you're putting up an image on the Web, having a thumbnail
  embedded in it is just a waste of download time anyway.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 26 Sep 2001 10:45:52
Message: <3BB1EA77.5308AB5@sycomore.fr>
First thing to know is, are there many persons suffering from
this? Right now, from what Thorsten and Ron just wrote, it
seems more of a mis-configured Photoshop than anything else.
If lot of people have such problems, it could be time for a
new entry in the VFAQ (along the lines "there are lots of
ways to write jpeg files, please try all the settings your
application has").
Adrien Beau - adr### [at] freefr - http://adrien.beau.free.fr
 Mes propos n'engagent que moi et en aucun cas mes employeurs
Date: 26 Sep 2001 10:56:22
Message: <3bb1ec96@news.povray.org>
In article <3BB### [at] sycomorefr> , Adrien Beau
> application has").
No, we actually have reports from other people with different programs that
also cause problem.  The main reason it is so hard to fix is that POV-Ray
actually uses the same JPEG library almost all other free programs use (the
Independent JPEG group's library).  So in theory there should be no problem
at all, but for some odd reason there is.  I have a copy of the JPEG
standard somewhere, and if/when my time permits I do plan to look into it,
but not this week...
    Thorsten
e-mail: tho### [at] trfde
Date: 26 Sep 2001 11:04:19
Message: <3bb1ee73@news.povray.org>
3bb1e7bc$1@news.povray.org...
> Maybe, before a solution is found, we could establish (trough our various
> experiences) a list of software that writes jpeg's suitable for POV-Ray ?
Microsoft Image Composer : OK
Picture Publisher 8 : not OK
Painter Classic : OK
Gimp for Windows : OK if native, but not-OK files can stay that way even
when resaved.
There may be also some big commercial application not working because every
JPEG map I tested from Poser or DAZ3D is refused by Povray.
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Date: 26 Sep 2001 11:12:33
Message: <slrn9r3s32.9g2.ron.parker@fwi.com>
>> application has").
It might really be our problem.  An image Gilles provided that refuses to parse
at all under POV works okay with djpeg.  Here's what djpeg says in the debug
output:
Independent JPEG Group's DJPEG, version 6a  7-Feb-96
Copyright (C) 1996, Thomas G. Lane
Start of Image
JFIF APP0 marker, density 72x72  1
Skipping marker 0xed, length 4490
Skipping marker 0xe2, length 3160
Adobe APP14 marker: version 100, flags 0x8000 0x0000, transform 1
Define Quantization Table 0  precision 0
Define Quantization Table 1  precision 0
Start Of Frame 0xc0: width=932, height=933, components=3
    Component 1: 2hx2v q=0
    Component 2: 1hx1v q=1
    Component 3: 1hx1v q=1
Define Restart Interval 59
Define Huffman Table 0x00
Define Huffman Table 0x01
Define Huffman Table 0x10
Define Huffman Table 0x11
Start Of Scan: 3 components
    Component 1: dc=0 ac=0
    Component 2: dc=1 ac=1
    Component 3: dc=1 ac=1
  Ss=0, Se=63, Ah=0, Al=0
End Of Image
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 26 Sep 2001 11:56:37
Message: <3bb1fab5@news.povray.org>
> when resaved.
Let me add :
XnView : OK
Corel Photo Paint 8 : OK
CompuPic Pro : OK
Microsoft Photo Editor (W2K) : OK
(all I had at hand at work, I'll test others at home).
P.S. : I see you are using Painter Classic.  Does it mean you are the
lucky owner of some graphic tablet ?  (I just bought a Wacom Intuos A5
myself).
Fabien.
Date: 26 Sep 2001 12:02:05
Message: <slrn9r3uvu.9qe.ron.parker@fwi.com>
>output:
AHA!
It turns out that the skip routine is supposed to skip in the buffer as well
as in the file.  I've just made a change that should fix this once and for
all (next beta, you know the drill...)
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 27 Sep 2001 11:51:30
Message: <3bb34b02@news.povray.org>
well
Aaah, BIG thanks...
Now, since you're at it, what about this little thingy about TIFF files
being inverted in uv-maps :-) I know it's not top priority bug but still...
G.
Graphic experiments
Pov-ray gallery
z)R(-z _-z)
S(_)9-(_1-
x*90}
Date: 28 Sep 2001 10:22:10
Message: <slrn9r91sk.5an.ron.parker@fwi.com>
>well
>Aaah, BIG thanks...
Just UV-maps, or everywhere?  It seems that we ignore what the TIFF library
tells us about the orientation of the image.  Whether that's something that'll
be easy to fix is anybody's guess, but it seems like it should affect more
than just UV maps.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 29 Sep 2001 06:47:47
Message: <3bb5a6d3$1@news.povray.org>
library
that'll
> than just UV maps.
Yes, you're right. Regular mapping has to be inverted as well to work
properly. There's more, in fact, as even with the scaling <1,-1,1> is
applied as a workaround, the uv still doesn't look right (it's a mirror
image). Or is it a mesh2 problem ???
I posted a test scene in beta-test.binaries.
G.
Graphic experiments
Pov-ray gallery
x}rotate
1rotate 60
Parker
