POV-Ray : Newsgroups : povray.beta-test : Problems with height_field Server Time
19 Feb 2026 04:18:48 EST (-0500)
  Problems with height_field (Message 1 to 2 of 2)
Subject: Problems with height_field
Date: 24 Sep 2001 18:55:32
Message: <3BAFBA26.BCB2C094@b0n541.net>
Hm, it's not my day I think. O.k. let's start:
My machine is still a Athlon 1 GHz, 396 MB RAM, Win98 SE, POV-Ray 3.5
Beta 4.
At first I tried to render a grey scale image for a height field. I
copied the source code from the help section 3.4.3  Height Field Object:
//-- Start of code --//
global_settings
        assumed_gamma 2.2
        hf_gray_16
camera { location <0, 0, -10> look_at 0}
light_source { <0, 20, -100> color White }
plane { z, 10
        pigment {wrinkles
                color_map
                        [0 0.3*White]
                        [1 White]
//-- End of code --//
This gives the error: File Init Error: Cannot open output file
This error occurs with all file types POV-Ray can do. After commenting
out the "hf_gray_16" in the global_settings it renders fine.
Second thing:
POV-Ray does not accept PNG-Files as input file for a height_field. It
gives the error: Parse Error: Unknown image type in image_height_at.
This has also an effect on the rerendering of the insert menu images.
The image for the height_field+image_map in Menu Insert/Shapes. This
doesn't render too.
So, I go to bed now, before I find more worse things ;-)
By,
Bonsai
Subject: Re: Problems with height_field
Date: 24 Sep 2001 22:25:59
Message: <slrn9qvqpq.f7.ron.parker@fwi.com>
See the thread titled "hf_gray_16" in this newsgroup for more information.
>Second thing:
>doesn't render too.
This is broken for TIFF, too.  It should be fixed in the next beta.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
