POV-Ray : Newsgroups : povray.beta-test : Error in insert menu: #switch example Server Time
14 Oct 2025 06:42:55 EDT (-0400)
  Error in insert menu: #switch example (Message 1 to 1 of 1)
Subject: Error in insert menu: #switch example
Date: 10 Sep 2001 18:58:30
Message: <3B9D4556.3B893291@hotmail.com>
This is what one get when one choose the
Insert->Misc. Directives->switch example
menu item:
// Let's make some constant names
#declare CS_Easy   = 1
#declare CS_Medium = 3
#declare CS_Hard   = 5
// Let the user choose the method to use
#declare Complexity_Switch = CS_Medium // or CS_Easy or CS_Hard
// Do something dependent on the user's choice
#switch (Complexity_Switch)
  #case (CS_Easy)
  // This statement is done if (Complexity_Switch = CS_Easy)
  #declare MyShape = box{-1,+1}
  #break // end of CS_Easy
  #case (CS_Medium, CS_Hard)
  // This statement is done if Complexity_Switch is CS_Medium
  // or CS_Hard or anything in between
  #declare MyShape = torus{1, 0.5}
  #break // end of CS_Hard
  #else
  // This statement is done if none of the above match
  #declare MyShape = sphere{0,1}
The code above contains several errors:
Semicolons should be added after 4 of the
declarations.
And in this line:
case is used instead of range.
This line has a wrong comment:
Some indentation would also make it all clearer.
And a little whitespace makes it easier to read !
Below is my suggestion for this menu item.
Tor Olav
#declare CS_Medium = 1;
#declare CS_Hard = 3;
#declare CS_Easy = 5;
#declare Complexity_Switch = CS_Medium; // or CS_Easy or CS_Hard
  #case (CS_Easy)
    // This statement is done if Complexity_Switch is CS_Easy
    #declare MyShape = box { -<1, 1, 1>, <1, 1, 1> }
  #break // End of this case section
  #range (CS_Medium, CS_Hard)
    #declare MyShape = torus { 1, 0.5 }
  #break // End of this range section
  #else
    #declare MyShape = sphere { <0, 0, 0>, 1 }
#end // End of switch statement
