This is what one get when one choose the
Insert->Misc. Directives->switch example
menu item:
// Let's make some constant names
#declare CS_Easy = 1
#declare CS_Medium = 3
#declare CS_Hard = 5
// Let the user choose the method to use
#declare Complexity_Switch = CS_Medium // or CS_Easy or CS_Hard
// Do something dependent on the user's choice
#switch (Complexity_Switch)
#case (CS_Easy)
// This statement is done if (Complexity_Switch = CS_Easy)
#declare MyShape = box{-1,+1}
#break // end of CS_Easy
#case (CS_Medium, CS_Hard)
// This statement is done if Complexity_Switch is CS_Medium
// or CS_Hard or anything in between
#declare MyShape = torus{1, 0.5}
#break // end of CS_Hard
#else
// This statement is done if none of the above match
#declare MyShape = sphere{0,1}
The code above contains several errors:
Semicolons should be added after 4 of the
declarations.
And in this line:
case is used instead of range.
This line has a wrong comment:
Some indentation would also make it all clearer.
And a little whitespace makes it easier to read !
Below is my suggestion for this menu item.
Tor Olav
#declare CS_Medium = 1;
#declare CS_Hard = 3;
#declare CS_Easy = 5;
#declare Complexity_Switch = CS_Medium; // or CS_Easy or CS_Hard
#case (CS_Easy)
// This statement is done if Complexity_Switch is CS_Easy
#declare MyShape = box { -<1, 1, 1>, <1, 1, 1> }
#break // End of this case section
#range (CS_Medium, CS_Hard)
#declare MyShape = torus { 1, 0.5 }
#break // End of this range section
#else
#declare MyShape = sphere { <0, 0, 0>, 1 }
#end // End of switch statement
