Running a first test or two of existing code (MegaPov 0.7) I believe I
have found a small problem:
The following code generates the error "font not found". Replacing the
POV string variable font_to_map
with an actual string works.
#declare font_to_map = "c:\WINDOWS\FONTS\musical.ttf"
#declare theChar = 110;
#declare character =
text { ttf font_to_map chr(theChar) 0.1, 0
pigment { color Black }
scale 10
translate <0,0,0>
And what happens when you specify the backslashes the proper way?
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
What do you mean? I don't see an error with his example.
Especially since he adds that the same string works when
put "as-is" in in the text bloc.
Or perhaps it's missing a semicolon at the end of the
string declaration?
Adrien Beau - adr### [at] freefr - http://adrien.beau.free.fr
Mes propos n'engagent que moi et en aucun cas mes employeurs
See doc 6.1.7.1
Ingo
Pov-Ray : http://members.home.nl/seed7/
"ingo" <ing### [at] homenl> wrote in message
news:Xns### [at] povrayorg...
> See doc 6.1.7.1
> Ingo
OK, my sloppiness...however it has always worked before
and still does if a literal string is used as opposed to a variable
containing a string which could be confusing to the neophyte
as well as to me.
Nigel
> as well as to me.
If you use a string in a text{} bloc at the appropriate place,
POV "knows" it is a filename and doesn't transform the backslahes.
On the other hand, if you define a string, POV has no way to
know what use it will be put to, so it has to parse it and change
the backslashes. Just guessing, of course.
In article <3B98B29A.AC3C91D3@sycomore.fr> , Adrien Beau
This is exactly how it works.
BTW, the proper way to solve the problem with the scene would be not to use
the absolute path in the first place. A library path should be used in the
INI file. For fonts putting the lib path in the povray.ini file would be
the best solution. This would also allow others to use the scene without
modification.
Thorsten
e-mail: tho### [at] trfde
