POV-Ray : Newsgroups : povray.beta-test : RC4 quick summary of my reports Server Time
25 Jul 2026 10:18:39 EDT (-0400)
  RC4 quick summary of my reports (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: RC4 quick summary of my reports
Date: 8 May 2002 14:21:18
Message: <3cd96c9e@news.povray.org>
> It is Messege ID! It works fine with both prefixes news:// and http://
> Usually I add http:// hovewer this time I removed it intentionally
> becouse of idea of justification.
Sorry, I didn't notice that. Maybe it's better if the news.povray.org/
in front of the message ID is removed. Or it's my newsreader's fault. I
don't know.
Felix Wiemann
Date: 9 May 2002 05:56:40
Message: <3cda47d8@news.povray.org>
Skiba <abx### [at] babilonorg>  wrote:
>   splines:      news.povray.org/m4f7cug9ch19jbve8m8prf4vl8ima0rsma@4ax.com
>                 when point is added then type of spline is overwritten
>                 so bottom, second from right is wrong
I don't get what you want to say in the sentence above.
>   bounding:     news.povray.org/2g0dcu8kasg84pqde8hdq9d60nkoa1cvka@4ax.com
>                 sphere-sweeps are still clipped
Yes, and this will remain the way it is unless someone comes up with code to
determine the bounding box of a Catmull-Rom spline segment.  It turns out the
original sphere_sweep code simply adds a bit to the control point bounding
box.  The problem appears only for Catmull-Rom splines because they may exceed
their control points which the code uses to find the bounding...
>   evaluate msg: news.povray.org/4nhfduk9gon9m76s6f6vu3k8gsjf7rrdjp@4ax.com
>                 end of paragraph makes suggested value of evaluate valid
>                 for report of next evaluate
I don't get what is supposed to be wrong here?!?
    Thorsten
e-mail: tho### [at] trfde
Date: 9 May 2002 06:55:30
Message: <pckkduod909g1736lrlm75pakanfm5rs3u@4ax.com>
On Thu, 09 May 2002 11:56:33 +0200, "Thorsten Froehlich" <tho### [at] trfde>
Sorry if it is caused by me English. I try to write it again and show shorter
example: when I copy spline identifier and add point in the same time then I
expect that new spline will have the same type and new point. Point is added
but type of spline is overwritten. Example:
  #macro Draw(Spline,Color)
    #local c=0;
    #while (c<1)
      sphere{Spline(c) .1 translate 3*z pigment{Color} finish{ambient 1}}
      #local c=c+.01;
  background{1}
  #local S=spline{ cubic_spline -1 5*x 0 x 1 y 2 5*y }
  Draw(S,red 1)
  Draw(spline{S 0.5 x+y},blue 1)
I see.
Nothing is wrong. The problem is that it is just less readable when suggested
values are connected in this paragraph with evaluated values of next evaluate.
Just problem of place of "\n" placing. But if it is caused by internall
wraping system for all messages then probably nothing to worry about - values
are (I suppose) correct.
ABX
Date: 9 May 2002 09:25:19
Message: <3cda78bf$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3cda47d8@news.povray.org...
to
the
exceed
If there is already code for the bounding box of a Bezier spline segment,
is it difficult to internally convert Catmull-Rom spline segment into Bezier
one
(to find the two additional control points) and to use it?
Gleb
Date: 9 May 2002 12:08:22
Message: <3cda9ef6@news.povray.org>
In article <3cda78bf$1@news.povray.org> , "Gleb" <gk1### [at] sotonacuk> wrote:
In case you did not notice, we are talking about too tight bounding here.  So
this is not the question.  All sphere_sweeps are bounded for speed reasons -
and you don't want to render any sphere_sweep without bounding!
> one (to find the two additional control points) and to use it?
A Catmull-Rom spline can extend "beyond" its control points.  It is not a
matter of converting to some other spline type.  The problem is to determine
the bounds of a Catmull-Rom spline segment by just looking at the control
points, which is simply not possible due to the nature of this spline type.
To clarify my original point:
This is not going to be fixed because nobody in the team has the time to look
into this mess.  Making wild suggestions won't help ;-)
Only plain and simple source code, based on the available sphere_sweep code
that can be found in MegaPOV, if contributed by someone _soon_, will fix the
problem in the initial 3.5 release.  The code was already been broken in the
original patch :-(  Its author apparently did not know a good way how to fix
it either, so don't expect magic from us!
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 9 May 2002 18:35:13
Message: <3cdaf9a1@news.povray.org>
> too tight bounding here.  So this is not the question.
Perhaps he did notice and perhaps he has a valid point. You are always
very quick to reject other people's suggestions as being nonsense or
irrelevant.
Anyway, please see my post in povray.beta-test.binaries for a suggestion
for bounding which is inspired my Gleb's message.
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated Apr 14)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Date: 9 May 2002 19:39:44
Message: <3CDB07F1.74542145@hotmail.com>
I have not looked very closely at this, but I don't
think it that it should be very difficult to find an
analytical solution to this.
As I understand it, there should be 3 cubic polynomials
that controls the x, y and z components for each segment.
Just differentiate these (to quadratic polynomials) and
solve for zero to find the max and min points of the
cubic polynomials. The values of the cubic polynomials
at these points will give the components for the
bounding box.
If any of the cubic polynomials has no real roots, then
I think that values at the endpoints of the cubic will
polynomials give the max and min points for the spline
segment.
Tor Olav
Date: 10 May 2002 09:44:18
Message: <3cdbceb2@news.povray.org>
news:3cda9ef6@news.povray.org...
determine
type.
look
code
the
the
fix
Why not ;)
Thank you for pointing the source,
it would be easier to explain what I mean.
In the source mentioned every spline segment
of this scaring Catmull-Rom spline
is internally represented as four polynomial coefficients, say
a3, a2, a1 and a0. Actual curve segment is calculated
as a3*t^3+a2*t^2+a1*t+a0. And every such a segment has two
control points at its ends from original definition.
And of course, the curve can escape the set of original control points.
What I'm talking about is that there are two "additional control points"
hidden inside this polynomial, because the same beast can also be
represented as
a3*t^3+a2*t^2+a1*t+a0 = A*(1-t)^3+3*B*t*(1-t)^2+3*C*t^2*(1-t)+D*t^3
which is the other scaring thing, Bezier spline segment.
In this form(for exactly the same curve) we have four control points,
A, B, C, D, where A and D are the same as the original Catmull-Rom spline
segment control points, but we also have two additional control points,
B and C. And our segment now can't escape the convex hull
of that set of the four control points.
And if there is already working code for calculating the bounding box
for Bezier spline segments, we can feed it with these four control
points - that's all.
On the other hand the method suggested by Tor Olav may be even better
(more precise).
Gleb
Date: 14 May 2002 02:21:03
Message: <d091eu092vqvbnn84edd8h1hv63t6bd27h@4ax.com>
On Thu, 09 May 2002 18:08:14 +0200, "Thorsten Froehlich" <tho### [at] trfde>
I have not noticed any announcement that somebody started to code this so I
used some part of my night to prepare code. Some notes:
- I did it completly without parser/compiler so it is not verified for syntax
  (in particular I wrote something in C long time ago and I don't remeber
  referencing rules)
- I was tired (but enthusiastic about it)
- I hope it isn't too late and used spline equations are correct
- I added some helper functions and made note how it could be improved by
  adding Bound union of boxes to additionaly optimize intersection test
- I used MEGAPOV 0.6a source
DBL Compute_B_Spline_Value(DBL t)
  // should be best to code this using already defined B_Matrix
  return 1/6*(-p0+3*p1-3*p2+p3)*t^3
        +1/2*(p0-2*p1+p2)*t^2
        +1/2*(-p0+p2)*t
        +1/6*(p0+4*p1+p2);
void Compute_Min_Max_B_Spline(DBL p0,p1,p2,p3,*minp,*maxp)
  DBL a,b,c,delta;
  // first derivative of spline equation is
  // 1/2*(-p0+3*p1-3*p2+p3)*t^2+(p0-2*p1+p2)*t-1/2*p0+1/2*p2
  a=1/2*(-p0+3*p1-3*p2+p3);
  b=p0-2*p1+p2;
  c=(-p0+p2)/2;
  d=b*b-4*a*c;
  if ((d<0)||(a==0)) // for unexpected errors return the biggest bbox
      t1=0;
      t2=1;
  else
      // parameter for extremas
      t1=(-b-sqrt(d))/(2*a);
      t2=(-b+sqrt(d))/(2*a);
      // parameter should be clipped to visible part of segment
      t1=min(max(t1,0),1);
      t2=min(max(t2,0),1);
  t1 = Compute_B_Spline_Value(t1);
  t2 = Compute_B_Spline_Value(t2);
  minp = min( t1, t2 );
  maxp = max( t1, t2 );
DBL Compute_Catmull_Rom_Spline_Value(DBL t)
  // should be best to code this using already defined Catmull_Rom_Matrix
  return ((2*p1)+(-p0+p2)*t+(2*p0-5*p1+4*p2-p3)*t^2+(-p0+3*p1-3*p2+p3)*t^3)/2;
void Compute_Min_Max_Catmull_Rom_Spline(DBL p0,p1,p2,p3,*minp,*maxp)
  DBL a,b,c,delta;
  // -1/2*p0+1/2*p2+(2*p0-5*p1+4*p2-p3)*t+3/2*(-p0+3*p1-3*p2+p3)*t^2
  a=3*(-p0+3*p1-3*p2+p3)/2;
  b=2*p0-5*p1+4*p2-p3;
  c=(-p0+p2)/2;
  d=b*b-4*a*c;
      t1=0;
      t2=1;
  else
  t1 = Compute_Catmull_Rom_Spline_Value(t1);
  t2 = Compute_Catmull_Rom_Spline_Value(t2);
void Compute_Sphere_Sweep_BBox(Sphere_Sweep)
SPHERE_SWEEP *Sphere_Sweep;
  VECTOR mins,maxs,segmins,segmaxs;
  int i,number_of_segments;
  DBL min_radius,max_radius;
  if( Sphere_Sweep->Interpolation == LINEAR_SPLINE)
    number_of_segments=Sphere_Sweep->Num_Modeling_Spheres-1;
  else
    number_of_segments=Sphere_Sweep->Num_Modeling_Spheres-3;
  // set initial value for general bbox extents
  // to one of "visible" control points of object
  Assign_Vector( mins , Sphere_Sweep->Modeling_Sphere[1].Center );
  Assign_Vector( maxs , Sphere_Sweep->Modeling_Sphere[1].Center );
  for (i = 0; i < number_of_segments; i++)
      // set initial value for local bbox extents
      // to one of "visible" control points of segment
      Assign_Vector( segmins , Sphere_Sweep->Modeling_Sphere[i+1].Center );
      Assign_Vector( segmaxs , Sphere_Sweep->Modeling_Sphere[i+1].Center );
      switch (Sphere_Sweep->Interpolation)
         case B_SPLINE:
             Sphere_Sweep->Modeling_Sphere[I  ].Center[X],
             Sphere_Sweep->Modeling_Sphere[i+1].Center[X],
             Sphere_Sweep->Modeling_Sphere[i+2].Center[X],
             Sphere_Sweep->Modeling_Sphere[i+3].Center[X],
             segmins[X],
             segmaxs[X]
             Sphere_Sweep->Modeling_Sphere[I  ].Center[Y],
             Sphere_Sweep->Modeling_Sphere[i+1].Center[Y],
             Sphere_Sweep->Modeling_Sphere[i+2].Center[Y],
             Sphere_Sweep->Modeling_Sphere[i+3].Center[Y],
             segmins[Y],
             segmaxs[Y]
             Sphere_Sweep->Modeling_Sphere[I  ].Center[Z],
             Sphere_Sweep->Modeling_Sphere[i+1].Center[Z],
             Sphere_Sweep->Modeling_Sphere[i+2].Center[Z],
             Sphere_Sweep->Modeling_Sphere[i+3].Center[Z],
             segmins[Z],
             segmaxs[Z]
             Sphere_Sweep->Modeling_Sphere[I  ].Radius,
             Sphere_Sweep->Modeling_Sphere[i+1].Radius,
             Sphere_Sweep->Modeling_Sphere[i+2].Radius,
             Sphere_Sweep->Modeling_Sphere[i+3].Radius,
             min_radius,
             max_radius
         break;
         case CATMULL_ROM_SPLINE:
             segmins[X],
             segmaxs[X]
             segmins[Y],
             segmaxs[Y]
             segmins[Z],
             segmaxs[Z]
             min_radius,
             max_radius
         break;
         case LINEAR_SPLINE:
           segmins[X] = min( segmins[X],
                        Sphere_Sweep->Modeling_Sphere[i].Center[X] );
           segmins[Y] = min( segmins[Y],
                        Sphere_Sweep->Modeling_Sphere[i].Center[Y] );
           segmins[Z] = min( segmins[Z],
                        Sphere_Sweep->Modeling_Sphere[i].Center[Z] );
           segmaxs[X] = max( segmins[X],
           segmaxs[Y] = max( segmins[Y],
           segmaxs[Z] = max( segmins[Z],
           max_radius = max( Sphere_Sweep->Modeling_Sphere[i].Radius ,
                        Sphere_Sweep->Modeling_Sphere[i+1].Radius );
         break;
      // consider maximal value of radius
      mins[X] = mins[X]-max_radius;
      mins[Y] = mins[Y]-max_radius;
      mins[Z] = mins[Z]-max_radius;
      maxs[X] = maxs[X]+max_radius;
      maxs[Y] = maxs[Y]+max_radius;
      maxs[Z] = maxs[Z]+max_radius;
      // here you can create box{mins maxs} object as bounding object
      // of current segment - for further optimization union of bounding
      // objects can be used as Bound field of current sphere_sweep
      // compare segment extents with object extents
      mins[X] = min( segmins[X], mins[X] );
      mins[Y] = min( segmins[Y], mins[Y] );
      mins[Z] = min( segmins[Z], mins[Z] );
      maxs[X] = max( segmins[X], maxs[X] );
      maxs[Y] = max( segmins[Y], maxs[Y] );
      maxs[Z] = max( segmins[Z], maxs[Z] );
  Make_BBox_from_min_max(Sphere_Sweep->BBox, mins, maxs);
  if (Sphere_Sweep->Trans != NULL)
      Recompute_BBox(&Sphere_Sweep->BBox, Sphere_Sweep->Trans);
ABX
Date: 14 May 2002 02:37:00
Message: <ftb1euon0h27vscfcjmfjd1cuqlbmvrluh@4ax.com>
yes, I was tired, I found mistake:
should be:
      segmins[X] = segmins[X]-max_radius;
      segmins[Y] = segmins[Y]-max_radius;
      segmins[Z] = segmins[Z]-max_radius;
      segmaxs[X] = segmaxs[X]+max_radius;
      segmaxs[Y] = segmaxs[Y]+max_radius;
      segmaxs[Z] = segmaxs[Z]+max_radius;
      // here you can create box{segmins segmaxs} object as bounding object
ABX
