POV-Ray : Newsgroups : povray.beta-test : RC4 quick summary of my reports Server Time
25 Jul 2026 08:27:10 EDT (-0400)
  RC4 quick summary of my reports (Message 14 to 23 of 23)
Subject: Re: RC4 quick summary of my reports
Date: 14 May 2002 14:15:11
Message: <3ce1542f@news.povray.org>
"W?odzimierz ABX Skiba" <abx### [at] babilonorg> wrote in message
news:d091eu092vqvbnn84edd8h1hv63t6bd27h@4ax.com...
> void Compute_Min_Max_B_Spline(DBL p0,p1,p2,p3,*minp,*maxp)
>   DBL a,b,c,delta;
>   // first derivative of spline equation is
>   // 1/2*(-p0+3*p1-3*p2+p3)*t^2+(p0-2*p1+p2)*t-1/2*p0+1/2*p2
>   a=1/2*(-p0+3*p1-3*p2+p3);
>   b=p0-2*p1+p2;
>   c=(-p0+p2)/2;
>   d=b*b-4*a*c;
>   if ((d<0)||(a==0)) // for unexpected errors return the biggest bbox
>       t1=0;
>       t2=1;
>   else
>       // parameter for extremas
>       t1=(-b-sqrt(d))/(2*a);
>       t2=(-b+sqrt(d))/(2*a);
>       // parameter should be clipped to visible part of segment
>       t1=min(max(t1,0),1);
>       t2=min(max(t2,0),1);
>   t1 = Compute_B_Spline_Value(t1);
>   t2 = Compute_B_Spline_Value(t2);
>   minp = min( t1, t2 );
>   maxp = max( t1, t2 );
> DBL Compute_Catmull_Rom_Spline_Value(DBL t)
>   // should be best to code this using already defined Catmull_Rom_Matrix
>   return
((2*p1)+(-p0+p2)*t+(2*p0-5*p1+4*p2-p3)*t^2+(-p0+3*p1-3*p2+p3)*t^3)/2;
> void Compute_Min_Max_Catmull_Rom_Spline(DBL p0,p1,p2,p3,*minp,*maxp)
>   DBL a,b,c,delta;
>   // -1/2*p0+1/2*p2+(2*p0-5*p1+4*p2-p3)*t+3/2*(-p0+3*p1-3*p2+p3)*t^2
>   a=3*(-p0+3*p1-3*p2+p3)/2;
>   b=2*p0-5*p1+4*p2-p3;
>   c=(-p0+p2)/2;
>   d=b*b-4*a*c;
>       t1=0;
>       t2=1;
>   else
>   t1 = Compute_Catmull_Rom_Spline_Value(t1);
>   t2 = Compute_Catmull_Rom_Spline_Value(t2);
Two remarks:
1) the only difference between procedures Compute_Min_Max_B_Spline and
Compute_Min_Max_Catmull_Rom_Spline is their polynomial coefficients a,b,c,d,
maybe it's better to put this common part in a separate procedure;
2) the curve can possibly reach its min/max at its ends, when t=0 and t=1.
Gleb
Date: 15 May 2002 02:03:27
Message: <e6u3eu0h9scfphre7glpfvadu0bbsvbikt@4ax.com>
On Tue, 14 May 2002 19:15:10 +0100, "Gleb" <gk1### [at] sotonacuk> wrote:
> Two remarks:
That was obvious conclusion when I wrote this stuff, moreover it could be
probably written in general form with one matrix as parameter (valid also
for linear spline) but I had no access to compiler and net to make it so I
wrote simplest form I could at that moment.
so whole discussion has no sense ? :-)
ABX
Date: 15 May 2002 04:04:18
Message: <3ce21682$1@news.povray.org>
news:e6u3eu0h9scfphre7glpfvadu0bbsvbikt@4ax.com...
t=1.
Of course it has :)
The only thing to fix this is to check that after calculating the local
min/max values for x,y,z.
Date: 20 May 2002 06:52:32
Message: <lnkheu0s7p6hned869puv17cdqu3pu8noc@4ax.com>
wrote:
>  return local: news.povray.org/e3piut8anmf4cli4pnfmstadgc3nleqvb2@4ax.com
I can still cause crash with RC5. Just a few Render/Stop/Render/Stop cycles.
> not works as (I) expected
>  splines:      news.povray.org/m4f7cug9ch19jbve8m8prf4vl8ima0rsma@4ax.com
>  bounding:     news.povray.org/2g0dcu8kasg84pqde8hdq9d60nkoa1cvka@4ax.com
>  evaluate msg: news.povray.org/4nhfduk9gon9m76s6f6vu3k8gsjf7rrdjp@4ax.com
Any chance to see 'Known bugs' list. None of listed is fixed but I don't want
bother too much - I just don't know what is current status of those reports.
ABX
Date: 20 May 2002 09:22:02
Message: <3ce8f87a@news.povray.org>
Works fine here.
The report is incomplete.  The behavior you reported that could be reproduced
without a scene has been fixed and for the rest an example is needed.
Won't be fixed in 3.5 as previously explained.
Not a bug.
    Thorsten
e-mail: tho### [at] trfde
Date: 21 May 2002 09:55:06
Message: <6pjkeu44jb482k8f95uu964iroa78og3bj@4ax.com>
On Mon, 20 May 2002 15:21:58 +0200, "Thorsten Froehlich" <tho### [at] trfde>
> Works fine here.
Works fine here for nearly every render. But crashes after a few cycles
Render/Stop/Render/.../Render/Stop without finishing rendering.
What is wrong in example I posted in
pckkduod909g1736lrlm75pakanfm5rs3u@4ax.com ?
Previously was explained it won't be fixed "unless someone comes up with code
to determine the bounding box of a Catmull-Rom spline segment". What is wrong
with code I posted in ftb1euon0h27vscfcjmfjd1cuqlbmvrluh@4ax.com ?
ABX
Date: 21 May 2002 12:14:06
Message: <3cea724e@news.povray.org>
But then it can be a million things and doesn't even have to do anything with
macros.  If it can't be reproduced, I am afraid it won't get fixed ... of
course, what would really help is an always crashing example.
Nothing except thata I didn't remember this particular example.  I think I
have found that problem now and assume it was the only one left from your list
of spline problems?
To quote you in that thread:
>- I did it completly without parser/compiler so it is not verified for syntax
>   (in particular I wrote something in C long time ago and I don't remeber
>   referencing rules)
> - I was tired (but enthusiastic about it)
> - I hope it isn't too late and used spline equations are correct
> - I added some helper functions and made note how it could be improved by
>   adding Bound union of boxes to additionaly optimize intersection test
Essentially, my ikdea of some providing code was "fully tested" code, not code
I would need to debug myself and that would possibly need several iterations
until it completely works.  Without having time for it that is really the only
thing that could have been used.  Anyway, it is probably too late now.
    Thorsten
Date: 21 May 2002 12:30:03
Message: <94tkeu09ab6dtli7jmse4dt95hcaat32v9@4ax.com>
On Tue, 21 May 2002 18:14:04 +0200, "Thorsten Froehlich" <tho### [at] trfde>
Unfortunatelly it is only example I have :-(
> of spline problems?
Great!
I see, so I will test this when sources will be released. I hope with small
effort it will be possible to compile 3.5 with djgpp or free borland release.
Sounds promising :-)
ABX
Date: 22 May 2002 07:45:23
Message: <3ceb84d3@news.povray.org>
> code I would need to debug myself and that would possibly need several
> iterations
> only
Can ABX's code be included after the final release of 3.5?
Felix Wiemann
Date: 22 May 2002 08:52:54
Message: <3ceb94a6@news.povray.org>
In article <3ceb84d3@news.povray.org> , Felix Wiemann <Fel### [at] gmxnet>
I am sure that a few month after the initial 3.5 release there will be some
kind of bugfix release to include all the known bugs for which we get fixes
for from users and for the newly discovered bugs that we fix ourselves.
Also, as new compilers become available, we will of course keep POV-Ray
up-to-date as far as those are concerned in order to get the best performance
available.
Note however that we won't promise that the source code will be available on
day one of the official release for all platforms.  Only after the release
there will be time to make sure it can easily be compiled and the files are
complete and so on...
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
