POV-Ray : Newsgroups : povray.beta-test : POV-Ray 3.7 beta 37 64/32 bit Unofficial for Macintosh available Server Time
11 Jun 2026 22:40:32 EDT (-0400)
  POV-Ray 3.7 beta 37 64/32 bit Unofficial for Macintosh available (Message 1 to 10 of 11)
Subject: POV-Ray 3.7 beta 37 64/32 bit Unofficial for Macintosh available
Date: 29 Apr 2010 08:33:17
Message: <1jhps42.11il3gsnsg8csN%yvo.s@cancel_This_gmx.net>
With permission of the POV-Ray Team, POV-Ray 3.7 smp Unofficial beta 37
for Macintosh is available:
The application will expire on the 1st of july 2010 (and can be
re-enabled)
Changes
Please read the "Readme beta" file included in the archives or visit:
http://www.povray.org/beta/
Read carefully which version you should download:
1) 64 bit universal
For any Intel-based Macintosh and PPC G5 running Mac OS 10.5 or later,
download the 64 bit version at:
http://megapov.inetart.net/beta/pv37_64_b37.zip
This version is a universal binary containing a 32- and a 64 bit version
for any Intel-base Macintosh and a 64 bit version for PPC G5.
It will not run on systems prior to Mac OS 10.5.
2) 32 bit universal
For any Intel-based Macintosh and PPC G5 running Mac OS 10.4 or later
you can download the standard 32 bit version at:
http://megapov.inetart.net/beta/pv37_b37.zip
This version is a universal binary containing a 32 bit version for any
Intel-based Macintosh and a 32 bit for PPC G5.
It will not run on systems prior to Mac OS 10.4.
usual but important stuff:
Please note that this is an unofficial compile so that Macintosh users
can participate in beta testing.
The UI is the same as MacMegaPOV but the renderer is POV-Ray 3.7 without
any modification.
The UI does not reflect in any way how the final official version for
Macintosh is going to be.
You can report core bugs to the POV-Ray-Team but send all UI related
bugs to yvo(DOT)s(AT)gmx.net
Before sending bug reports, please read about this POV-Ray 3.7 release
and known bugs at:
and make sure the bug isn't reported at:
http://news.povray.org/povray.beta-test/
Please take a few moments to read the "Readme xx" files included in the
package before using the application!
Keep in mind that this is beta software!
Yvo
MegaPOV at:  http://megapov.inetart.net
MacMegaPOV at:  http://users.skynet.be/smellenbergh
E-mail: yvo(DOT)s(AT)gmx.net
Subject: Re: POV-Ray 3.7 beta 37 64/32 bit Unofficial for Macintosh available
Date: 15 Jun 2010 13:15:00
Message: <web.4c17b40dde48ab1c4f28787e0@news.povray.org>
Just tried this, MacBook running 10.4.11, it exits immediately on startup.
MegaPOV 1.2.1 runs fine (that's my regular POV version)... does the binary
expect to live anywhere specific?
Bill
Date: 15 Jun 2010 19:19:38
Message: <4c180a8a$1@news.povray.org>
for documentation purposes ... you won't happen to know what the default
value for Work_Threads (+wt) is would you? Windows is number of detected
cores, and linux/unix is 2 ... for completeness I was hoping to add that
information for our Mac friends :-)
cheers
jim
Date: 16 Jun 2010 07:31:04
Message: <4c18b5f8$1@news.povray.org>
Am 16.06.2010 01:24, schrieb Jim Holsenback:
The information you have about Linux is outdated; on Linux systems, +WT
defaults to the number of "online processors" if known and >1, otherwise
the number of "configured processors" if known and >1, otherwise 4.
Given that POV-Ray 3.7 for Mac is based on the Linux version, I'd
presume that it uses the same defaults.
Date: 16 Jun 2010 07:33:34
Message: <4c18b68e$1@news.povray.org>
Am 16.06.2010 13:30, schrieb clipka:
... ah, and not to forget that both Linux and Windows versions cap their
+WT defaults to 512.
Date: 16 Jun 2010 12:23:47
Message: <1jk6y0c.2n3dy61aucy9kN%yvo.s@cancel_This_gmx.net>
No, you can unzip the archive anywhere and run the application.
Just to be sure, you downloaded the 32 bit version?
The 64 bit version will not run on Mac OS 10.4.
You need this archive:
If this is what you use and it doesn't work, please contact me direct
via e-mail so that I can try to fix it.
Yvo
> Bill
Message: <1jk6ynt.z9pjl41ereracN%yvo.s@cancel_This_gmx.net>
This can be set via the menu "PovRay 3.7 Unofficial" >> "Preferences" >>
"Misc panel".
The default  is set to "Automatic" and then the number of physical cores
is used.
It is also possible to set any value from 1 to 6 and n-1 or n+1.
Automatic is in most cases the best.
But keep in mind that this is an unofficial version just until an
official version will be out!
Yvo
Date: 28 Jun 2010 03:30:01
Message: <web.4c284e7bde48ab1c77249da90@news.povray.org>
Hi everyone!
I just tried to get this beta but it seems, that the links are all down, as well
as the whole beta site from megaPov. Can anyone tell me where else to get the
mac beta? Would be awesome to have a working source for it!!
Thaks in advance!!
m0
Date: 28 Jun 2010 10:41:47
Message: <1jkt29w.111i9puzct7n4N%yvo.s@cancel_This_gmx.net>
> as well as the whole beta site from megaPov. Can anyone tell me where else
> to get the mac beta? Would be awesome to have a working source for it!!
You are looking at beta 37 but now you have to get beta 37a.
Look at this message for it:
http://news.povray.org/povray.beta-test/thread/%3C1jke34d.bnuxoz19nl1naN
%25yvo.s%40cancel_This_gmx.net%3E/
Older versions are always removed.
Yvo
Date: 27 Oct 2011 15:35:01
Message: <web.4ea9b143de48ab1c6634b6060@news.povray.org>
> Yvo
=> (october 2011) =>
http://megapov.inetart.net/beta/pv37_rc3.zip
seems that we have to guess the link each time ?
