POV-Ray : Newsgroups : povray.beta-test : isosurface MegaPov conversion to POV3.5 Server Time
14 Oct 2025 10:42:50 EDT (-0400)
  isosurface MegaPov conversion to POV3.5 (Message 1 to 5 of 5)
Subject: isosurface MegaPov conversion to POV3.5
Date: 9 Sep 2001 16:43:31
Message: <1ezhnxz.1xl4pg916b2xyyN%smellenbergh@skynet.be>
Here are some hints to convert syntax of MegaPov isosurface to 3.5
* braces {} are required with functions
  "function x+y"
should be
  "function {x+y}"
* parameters of a declared function must be specified when called
  #declare FUNC = function {x+y+z}
  isosurface { function {FUNC} }
should be
  isosurface { function {FUNC(x,y,z)} }
* using internal functions (See 7.7 functions.inc)
  all internal functions are included in the functions.inc and start
with
"f_xxx". Parameters are set between ( ) braces and begin with the x,y,z
parameters)
   So, MegaPov's "sphere",<0.8>
becomes
  #include "functions.inc"
  f_sphere(x,y,z,0.8)
or, when declaring the function directly, without using the include
file:
  #declare MySphere = function { internal(61) }
  isosurface{ function{ MySphere(x,y,z,0.8) } }
* noise3d
  in 3.5 noise3d is treated as an internal function: use the
function.inc and
  f_noise3d(x*4,y*4,z*4)/5
Note that the noise uses pov's noise generator set in the global
settings:
global_settings{
  noise_generator 1 //old 3.1g plateaud noise
  noise_generator 2 //MegaPov 0.5 noise
  noise_generator 3 //New 3.5 perlin noise
...or use
  f_noise_generator(x,y,z, P0)
    * P0 : Noise generator number
*The func_ names have been renamed
  func_0  >  f_ellipsoid
  func_1  >  f_blob
  func_2  >  f_flange_cover
  func_2b  >  f_blob2
  func_3  >  f_cross_ellipsoids
  func_4  >  f_isect_ellipsoids
  func_5  >  f_spikes
  func_9  >  f_poly4
  func_10  >  f_spikes_2d
  func_11  >  f_quantum
  func_12  >  f_helical_torus
  func_13  >  f_comma
  func_16  >  f_polytubes
And the duplicate functions have been removed
  helix1 / func_6  >  f_helix1
  helix2 / func_7  >  f_helix2
  spiral / func_8  >  f_spiral
  mesh1 / func_14  >  f_mesh1
* using function { pigments } in isosurfaces
  the pigment must be declared. When calling it, the dot notation must
be used: FUNC(x,y,z).x
This allows to use the channels of the color vector in a controlled way
Allowed are:
  .x .u .red, .y .v .green, .z .t .blue, .filter, .transmit for the
separate channels
  .gray or .grey for the gray value of the color vector
  .hf for the height_field value of the color vector (this was the
method used in MegaPov)
  #declare Granny = function{
    pigment{
      granite scale 3
      color_map { [0 rgb 0] [1 rgb 1] }
  isosurface{function{f_sphere(x,y,z,1)+Granny(x,y,z).hf*0.2}}
* sign is no longer used in 3.5 isosurface
to switch inside/outside, turn the whole function negative:
  #declare Landscape = function { f_ridged_mf(x,y,z,1,2,10,1.1,2) }
  isosurface{function{ Landscape(x,0,z)-y }
becomes
  isosurface{function{ -(Landscape(x,0,z)-y) }
* sqr and cub no longer supported
  use ^2 and ^3 ,or pow(A,2) and pow(A,3)
* sqrt x^y and ln are used in the mathematical form in 3.5
  Isosurface     MegaPov internal   3.5 internal
  sqrt(x)     =  sqrt(abs(x))       =sqrt(x)
  x^y         =  abs(x)^y           =x^y
  ln(x)       =  ln(abs(x))         =ln(x)
So, these MegaPov functions might need to be written as they have been
used internally in MegaPov to get the same results in 3.5
* if(A,B,C)
  has been replaced by select (A,C,B)
MegaPov
  isosurface {function {if(-x, abs(x)+abs(y)-0.5, sqrt(z^2+y^2)-0.5)}
becomes in 3.5
  isosurface{function{select(-x, sqrt(z^2+y^2)-0.5, abs(x)+abs(y)-0.5)}
* method 1 and method 2
  keywords no longer used in 3.5: a method 2-ish method is standard
* eval
  eval becomes evaluate and *requires* 3 parameters without the vector
braces: evaluate A,B,0.99 which is the same as MegaPov's eval <A,B,0.99>
I think these are the main changes, but I probably forgot some :-)
e-mail:sme### [at] skynetbe
http://users.skynet.be/smellenbergh
Subject: Re: isosurface MegaPov conversion to POV3.5
Date: 9 Sep 2001 20:56:23
Message: <3b9c0fb7$1@news.povray.org>
Merci Rene. This is a great help and will save me many hours of research.
Best,
Dennis
"smellenbergh" <sme### [at] skynetbe> wrote in message
news:1ezhnxz.1xl4pg916b2xyyN%smellenbergh@skynet.be...
>   "function x+y"
> should be
>   "function {x+y}"
> should be
> with
> parameters)
> becomes
>   f_sphere(x,y,z,0.8)
> file:
> * noise3d
> function.inc and
> settings:
> global_settings{
>   noise_generator 1 file://old 3.1g plateaud noise
>   noise_generator 2 file://MegaPov 0.5 noise
>   noise_generator 3 file://New 3.5 perlin noise
> ...or use
>   func_1  >  f_blob
>   func_2b  >  f_blob2
>   func_5  >  f_spikes
>   func_9  >  f_poly4
>   func_11  >  f_quantum
>   func_13  >  f_comma
> Allowed are:
> separate channels
>     pigment{
>       granite scale 3
> becomes
>   x^y         =  abs(x)^y           =x^y
> * if(A,B,C)
> MegaPov
> becomes in 3.5
> * eval
Date: 10 Sep 2001 13:10:06
Message: <N8tIiKAuDOn7Ewvz@econym.demon.co.uk>
Wasn't it smellenbergh who wrote:
[Lots of extremely useful stuff]
>file:
I'd guess that would be a bad idea. The "functions.inc" file is
insulating you from having to change your scene files whenever the
internal function numbers get changed. 'The ID's used to access the
internal functions through calls to "internal(XX)", are not guaranteed
to stay the same between POV-Ray versions.' (Help file 7.7)
If the authors keep the ID numbers in alphabetical order and a couple of
new ones get inserted you may well find that what you thought was a
sphere will become a ridged_multifractal.
>becomes
Note also that if your function used a threshold you must make that
negative too.
   threshold 0.5
becomes
   threshold -0.5
Also, some minor stuff.
MegaPOV accepted
        contained_by {sphere 0,1}
3.5 requires the brackets
        contained_by {sphere {0,1}}
MegaPOV required a contained_by keyword
3.5 defaults to {box{-1,1}}
MegaPOV built-in function names were case independent
        "Sphere"
3.5 requires lower case
        f_sphere
MegaPOV isosurfaces never suffered from coincident surface artefacts.
3.5 isosurfaces that have coincident surfaces get the traditional
coincident surface speckles. (So the MegaPOV trick of avoiding "open"
containers by making an invisible surface coincident with your container
doesn't work. However, 3.5 doesn't have much of a speed penalty for
having an "open" container, so you don't need the trick.)
The parametric isosurface syntax is completely different.
There's also probably lots of really clever new stuff that can be done
because of the way that 3.5 functions have become more flexible. For
example, in MegaPOV you couldn't #declare functions that had extra
parameters. In 3.5 I can create an include file that declares functions
that take extra parameters just like the built in functions do.
    #declare Whitneys_Umbrella = function(x,y,z,A,B){A*x*x -B*y*y*z}
can then be referenced like
    isosurface {
      function { Whitneys_Umbrella(x, y, z, 2, -1) }
Whereas in MegaPOV if I wanted a Whitney's Umbrella (2,-1) and another
Whitney's Umbrella(1,1) I'd have had to #declare them separately.
I've so far found that the hardest bit of converting my isosurface
tutorial scene files (and I've done over 150 of them so far) is finding
a sensible max_gradient in situations where I had previously used the
MegaPOV defaults.
Mike Williams
Gentleman of Leisure
Date: 21 Oct 2001 14:01:30
Message: <g836ttggsvfmeurpr6f34vg9en3pesog4m@4ax.com>
Hi There,
I have some megapov scenes that used the I_dat3d function  as below
function{"data_3D_1", <1> library "i_dat3d" ........ }
I can't find anything in the docs about this function.
Does anyone know how/if I can convert these scene files ?
Rob
On Sun, 9 Sep 2001 22:43:31 +0200, sme### [at] skynetbe
>  "function x+y"
>should be
>  "function {x+y}"
>should be
>with
>parameters)
>becomes
>  f_sphere(x,y,z,0.8)
>file:
>* noise3d
>function.inc and
>settings:
>global_settings{
>...or use
>  func_1  >  f_blob
>  func_2b  >  f_blob2
>  func_5  >  f_spikes
>  func_9  >  f_poly4
>  func_11  >  f_quantum
>  func_13  >  f_comma
>Allowed are:
>separate channels
>    pigment{
>      granite scale 3
>becomes
>  x^y         =  abs(x)^y           =x^y
>* if(A,B,C)
>MegaPov
>becomes in 3.5
>* eval
Date: 21 Oct 2001 14:36:51
Message: <Xns9141D1B29BEC9seed7@povray.org>
 These functions are not in 3.5. Maybe you can convert your source for
the i_dat3d stuff to a df3-file (density file) and use that as a
function.
Ingo
