POV-Ray : Newsgroups : povray.beta-test : v3.8 character set handling : Re: v3.8 character set handling Server Time
16 Nov 2025 10:04:36 EST (-0500)
Date: 12 Jan 2019 13:10:00
Message: <web.5c3a2ce8d2c7bd4748892b50@news.povray.org>
hi,
> To simplify conversion of old scenes, the text primitive syntax will be
> extended with a syntax allowing for more control over the lookup process:
>      #declare MyText = "a\u20ACb";
>      text { ttf "sym.ttf" cmap { 3,0 charset windows1252 } MyText }
with alpha.10008988, and same code as in other thread modified to read:
#version 3.8;
text { ttf "arialbd.ttf" cmap { 1,0 charset utf8 S }
I get the following error:
File 'pav-patt.pov' line 61: Parse Warning: Text primitive 'cmap' extension is
 experimental and may be subject to future changes.
File 'pav-patt.pov' line 61: Parse Error: Expected 'numeric expression', utf8
 found instead
Fatal error in parser: Cannot parse input.
Render failed
same for 'ascii'.
regards, jr.
