dick balaska <dic### [at] buckosoft com> wrote:
> > [on Windows 7 Ultimate 64-bit]
> > I'm getting a strange fatal error on all scene files that I try to run...
> > "cannot create render state output file"
> This says POV-Ray does not have permission to write to the directory.
My first thought was to check my (Windows)POV-Ray menu item, "Options/Script I/O
restrictions" (in case it had changed somehow), but it's set to:
No restrictions
Permit Read/Write in Current Directory
Disable Starting Other programs
BTW, no problem occurs when I run one of the older (3.7-folder) alpha or beta
versions-- just this 3.8.0 variant.
> The render state file is an intermediate file in case you want to
> abort/resume a render. You can turn it off with -CC on the command line,
> but then I'd bet that it won't have permission to write the output image
> to that directory either.
Good news: Adding -cc to the command line DOES work-- the scene now renders!
Thanks for that hint.
So apparently(?), the problem is with the state-file-writing mechanism, in some
way... (at least on my end)...
