(using Windows 7 64-bit)
I haven't used a light_group in a long time, so I can't remember exactly what
its behavior was in v3.62, but I don't think it's working correctly in the beta.
I've included a test scene below.
Although the light_group's light does not appear on objects outside the group
(which is correct), it's still casting shadows from those objects, onto the
object in the light_group. Is that proper behavior? I don't recall a similar
problem in v3.62 (although I could be wrong.) The included documentation doesn't
mention shadow behavior (except as relates to scattering media.)
Also, the light's looks_like object (yellow sphere) is showing lighting effects
from the extra 'global light', even with 'global_lights off' in the light_group
(although there's no shadow from that sphere, as far as I can tell.) I don't
know if that is correct behavior or not.
#version 3.71;
global_settings{assumed_gamma 1.0 max_trace_level 5}
perspective
location <0, 0, -3.5>
look_at <0, 0, 0>
angle 35
background {rgb .2}
// the extra 'global light'-- up and to the left
light_source {
0*x
color rgb <1,1,1>
translate <-30, 30, -10>
light_group{
light_source {
0*x
color rgb 80000*<1,.5,.5>
fade_power 1.5
fade_distance .001
looks_like{
sphere{0,.03 texture{pigment{rgb <1,.8,0>}finish{ambient 0 diffuse .9}}}
translate <.09, .2, -.06>
plane{y,-.61
texture{
pigment{
cells
scale .5
color_map{
[0 rgb .5]
[1 rgb 1]
finish{
ambient 0
diffuse .4
// global_lights on
// tall thin box
#declare TALL_BOX =
box{<-.02,-1,-.02>, <.02,1,.02>
texture{
pigment{rgb <.4,1,.4>}
rotate 30*y
object{TALL_BOX}
object{TALL_BOX
rotate 80*x
translate <-.3,-.3,.3>
