POV-Ray : Newsgroups : povray.beta-test : 3.7.0RC3 -- make check -- how long should the test run? : Re: 3.7.0RC3 -- make check -- how long should the test run? Server Time
12 Mar 2026 17:47:24 EDT (-0400)
Date: 22 Jun 2011 05:15:00
Message: <web.4e01b0f85d5b93c12b256d410@news.povray.org>
Le_Forgeron <jgr### [at] freefr> wrote:
> I wonder a bit about the construct
>   while ( !Stream.eof() )
>    // get and preprocess line
>    std::getline(Stream, line);
>    line = pre_process_conf_line(line);
>    ++line_number;
>    // skip empty line
>    if(line.length() == 0)
>     continue;
In my case, this loop was an endless loop. line.length() was always 0 and the
Stream.eof() never returned true (at least I checked this until line_number =
9).
I was interested in which file was actually parsed here:
(gdb) print conf_name
$7 = (const std::locale::string &) @0x92f7f8: {
  static npos = 18446744073709551615,
  _M_dataplus = {<std::allocator<char>> = {<__gnu_cxx::new_allocator<char>> =
{<No data fields>}, <No data fields>},
    _M_p = 0x92f928 "/home/bioinfp/jang/.povray/3.7/povray.conf"}}
And now it gets funny:
ls -ahl /home/bioinfp/jang/.povray/3.7/
1.5K drwxr-xr-x 2 jang bioinfp 2 2011-06-08 15:50 povray.conf/
povray.conf was a directory in my case. I removed it, restarted 'make check' and
the test worked fine (X window opened..."POV-Ray finished").
I think the path /home/bioinfp/jang/.povray/3.7/ existed due to some former
tries of myself to 'make install' povray. I have no idea why this povray.conf
existed as a _directory_ -- it may be my fault from earlier times. But you maybe
could add some more dir/file checking so that povray never tries to read lines
from a directory :-)
I removed ~/povray and invoked 'make install'. Now, there is only one small
problem left:
Creating data directories...
Copying data files...
Creating documentation directories...
Copying documentation files...
Creating user directories...
chown: changing ownership of `/home/bioinfp/jang/.povray': Operation not
permitted
chown: changing ownership of `/home/bioinfp/jang/.povray/3.7': Operation not
permitted
make[2]: *** [install-data-local] Error 1
make[2]: Leaving directory `/home/bioinfp/jang/sumpf/povray-3.7.0.RC3'
make[1]: *** [install-am] Error 2
make[1]: Leaving directory `/home/bioinfp/jang/sumpf/povray-3.7.0.RC3'
make: *** [install-recursive] Error 1
The installation works, but what does the make script try to do with the
permissions? And yes, my home directory is a mounted NFS.
Thanks for your help,
Jan-Philip
