POV-Ray : Newsgroups : povray.beta-test : Subset_Start_Frame doesn't work? : Subset_Start_Frame doesn't work? Server Time: 20 Mar 2010 22:18:42 GMT
Date: 3 Nov 2006 16:05:00
When I render an animation using an INI-file that contains the following
lines:
   Final_Frame=675
   Subset_Start_Frame=125
   Subset_End_Frame=276
I get frames 1 through 276, instead of 125 through 276.
Apparently, Subset_Start_Frame does not work and Subset_End_Frame does.
Same behaviour when I use +SF125.
Same behaviour when I use the commandline.
Am I missing something?
I'm running 3.7.0.beta.16.msvc8.win64
Thanks for your help and your time.
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
