POV-Ray : Newsgroups : povray.beta-test : 3.7 beta fails with out of memory - ok under 3.6 : Re: 3.7 beta fails with out of memory - ok under 3.6 Server Time
19 Mar 2026 23:01:49 EDT (-0400)
Date: 30 Oct 2006 10:35:01
Message: <web.45461b4a8f1b3f6c1e4bb4ba0@news.povray.org>
Chris Cason <del### [at] deletethistoopovrayorg> wrote:
> jva wrote:
> > However, it now seems there might be a problem: the minimal scene below cut
> > from the original glass scene uses hardly any memory at all and gives the
> > same problem whenever focal blur is on. It runs fine in povray 3.6 though.
> > Hope this helps, Jeroen.
> Yes, it did thanks. until the next beta you can work around it by keeping
> samples to 64 or less. the actual problem was the list of containing
> interiors was not being cleared between each ray sampled in the grid, and
> this eventually caused an overflow. I'm glad it did, too, because the
> accumulated interiors can also slow down the render unnecessarily, which is a
> bug that had not been reported.
> -- Chris
All,
     I tried setting BlurOk=0 and rendering the image, but there's something
wrong.... its strangely dark and renders quickly.
Any other suggestions for getting this image to render under the 3.7 SMP SSE
beta ?.
Adrian.
