POV-Ray : Newsgroups : povray.beta-test : 3.7 beta fails with out of memory - ok under 3.6 : Re: 3.7 beta fails with out of memory - ok under 3.6 Server Time
22 Mar 2026 12:10:03 EDT (-0400)
Date: 27 Oct 2006 09:50:00
Message: <web.45420e778f1b3f6c8be19fb80@news.povray.org>
"jva" <nomail@nomail> wrote:
> I tried rendering the scene at 512x384 and got the same out of memory error.
> It disappeared whenever I switched of focal blur (BlurOK=0) and proceeded to
> render fully. The other options didn't seem to make a difference for as far
> as I could see.
> Jeroen.
> Chris Cason <del### [at] deletethistoopovrayorg> wrote:
> > Adrian wrote:
> > > Try rendering http://en.wikipedia.org/wiki/Image:Glasses_800_edit.png
> > > at 1920x1200  with the 3.7 beta.
> > > Fails with out of memory error at the start.
> > > Fine under 3.6 though - I could really use the SMP/SSE2 on this one !.
> > Does it work at lower resolutions?
> > Try running with -d to turn off the preview display, see if that helps.
> > -- Chris
   So I guess that you agree this is a bug then ?.
Adrian.
