Hi Jim,
Thanks for the feedback.
This seems to be a very odd fault, as the code is almost identical to code I
often use and I can not discern anything wierd about it. I'm hoping the devs
can figure it out ...
Bye for now,
Mike Andrews.
"Jim Holsenback" <jho### [at] hotmail com> wrote:
> "Mike Andrews" <nomail@nomail> wrote in message
> news:web.44e5a00bfcc26e0fc717c9af0@news.povray.org...
> > Hi Folks,
> > I've posted a similar message on the Windows group about a small,
> > apparently
> > sensible scene, throwing an unhandled exception.
> > I've now tried a very similar scene on beta 14, causing it to exit on
> > completion. The scene is appended below. I can see nothing wrong with the
> > scene code and I'd appreciate knowing why it fails.
> > System: 933MHz PIII, 512Mb, Win XP Pro SP2, PoV-Ray
> > v3.7.0.beta.14.icl8.win32
> I got the same on my system however I'm running as follows:
> System: 2.39GHz P4 1GB Win XP Pro SP2, PoV-Ray v3.6.icl8.win32
> so either something got missed in the last release or it IS something with
> your code ....
> I was curious when I recalled I had v3.5.ic18.win32 installed as well so I
> ran your file using that version and it finished the render .....
> so maybe it's NOT your code .....
> Jim
