POV-Ray : Newsgroups : povray.beta-test : Small scene causing beta 14 to exit on completion ... : Small scene causing beta 14 to exit on completion ... Server Time
16 Dec 2025 05:08:08 EST (-0500)
Date: 18 Aug 2006 07:15:00
Message: <web.44e5a00bfcc26e0fc717c9af0@news.povray.org>
Hi Folks,
I've posted a similar message on the Windows group about a small, apparently
sensible scene, throwing an unhandled exception.
I've now tried a very similar scene on beta 14, causing it to exit on
completion. The scene is appended below. I can see nothing wrong with the
scene code and I'd appreciate knowing why it fails.
System: 933MHz PIII, 512Mb, Win XP Pro SP2, PoV-Ray
v3.7.0.beta.14.icl8.win32
Bye for now,
Mike Andrews.
// --- code starts ---
#declare camPos = 5*<-0.1,6,-5>;
camera{
  ultra_wide_angle
  up y
  right x*4/3
  location camPos
  look_at  0
  angle 50
#declare Phi=(sqrt(5)+1)/2;
#declare rPhi=2-Phi;
#declare Cen = (Phi-1)/(2*Phi-1);
#declare Ill = box {
  <0.1,-rPhi-0.1,-0.01>,<0.9,-0.1,0.01>
  translate <-Cen,0,-Phi*(1-Cen)>
#declare Scl = 1;
#declare Rot = 0;
#declare C = 0; #while (C < 10)
  object {
    Ill scale Scl rotate -Rot*y
    translate <Cen,0,Phi*(1-Cen)>-<0.5,0,Phi/2>
    rotate 90*y
    scale 20
    pigment { rgb 1 }
    finish { diffuse 0 ambient 1 }
  #declare Scl = Scl/Phi;
  #declare Rot = Rot+90;
#declare C = C + 1; #end
// --- code ends ---
