POV-Ray : Newsgroups : povray.beta-test : Darkness in GRENADINE.POV : Darkness in GRENADINE.POV Server Time: 18 Mar 2010 19:13:13 GMT
Date: 4 Jun 2006 21:00:00
Rendering scenes/advanced/grenadine.pov as it is gives a nearly completely
black picture. Commenting out the assumed_gamma statement doesn't make a
difference. Changing the photon spacing in global_settings { } to higher
values (>0.03) renders the scene correctly.
I've tried to make a more minimal scene out of it with just the lightsource,
the red liquid (no bubbles) and the background (photon settings, object
locations &c unchanged). This, however, doesn't manifest the issue.
Clearly, the problem must be somewhere else...
Hang on, just found that the problem disappears when NOT rendering in BSP
mode (so without command-line option +b2). I might try to make some
different abbreviated scenes to see exactly when the problem arrises, but
for now I hope this is of any use...
Jeroen.
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
