POV-Ray : Newsgroups : povray.beta-test : Seam bugs / issues with bump_map. : Seam bugs / issues with bump_map. Server Time
26 Oct 2026 08:20:01 EDT (-0400)
Date: 13 Feb 2025 22:06:42
Message: <67aeb342@news.povray.org>
I recently made a post in the pbi forum which mentioned that the
bump_map{} code has a seam bug. See:
http://news.povray.org/povray.binaries.images/thread/%3C67a154c1%241%40news.povray.org%3E/
Bald Eagle posted a link to: https://iquilezles.org/articles/tunnel/
which is a cousin to one of two issues found with the current POV-Ray
code. (Thanks Bill)
Details...
There are many factors which contribute to the vibrancy of the issues
found in any given render result. Very generally it's worse with the
bump_map due how it takes multiple samples from the image to implement
the normal perturbation. Yes, the issues exist with image_map{},
image_pattern{} and image_indexed_textures{} (formally material_map{})
too - but mostly in muted / harder to see ways.
With respect to bump_map{}, the first root issue is due the multiple
samples sometimes spanning the seam in a given mapping type. The second
root issue - sitting smack on top of the first - is that games are being
played internal to all interpolations which introduce / mangle the
values in the pixels at the images edges.
Attached is a v3.8 beta 2 compatible scene which shows the issues and
two images. A triangle_wave gradient of x*pi is used to create the input
image for the bump_map{} where the mapping is spherical. The camera is
zoomed in on a smaller part of the sphere's surface containing the seam.
Both images show No-interpolation and Bi-Linear interpolation in the top
row and Bi-Cubic and Normalized-distance in the bottom row.
The image bump_map_state.png shows the current state with both issues
present and overlapping.
The image bump_map_intrpIssues.png shows the interpolation issues in
isolation - with code where the first issue is fixed.
Bill P.
Download 'bump_map_intrpissues.png' (23 KB) Download 'bump_map_state.png' (18 KB)
Preview of image 'bump_map_intrpissues.png'
Preview of image 'bump_map_state.png'
