POV-Ray : Newsgroups : povray.beta-test : Photons are broken with true inverse squared lighting : Re: Photons are broken with true inverse squared lighting Server Time
13 Jul 2026 21:46:28 EDT (-0400)
Date: 20 Jun 2024 09:39:33
Message: <66743115$1@news.povray.org>
On 6/19/24 18:16, William F Pokorny wrote:
> I'll look at this tomorrow.
In source/core/lighting/photons.cpp there are two methods:
     void PhotonTrace::addSurfacePhoton()
     void PhotonMediaFunction::addMediaPhoton()
which have code like:
     if ((photonLight->Fade_Power > 0.0) &&
         (fabs(photonLight->Fade_Distance) > gkMinIsectDepthReturned))
         Attenuation = 2.0 /
         (1.0 + pow(threadData->photonDepth /
             photonLight->Fade_Distance, photonLight->Fade_Power)
     else
         Attenuation = 1;
In both methods, the code needs to be something like:
     if (photonLight->Fade_Power > 0.0)
         if (fabs(photonLight->Fade_Distance) >= gkMinIsectDepthReturned)
             Attenuation = 2.0 /
                 (1.0 + powf(threadData->photonDepth /
         else if (threadData->photonDepth >= gkMinIsectDepthReturned)
             Attenuation =
                 powf(threadData->photonDepth,-photonLight->Fade_Power);
         else
             Attenuation = 0.0;
     else if (photonLight->Fade_Power == 0)
         Attenuation = 1;
     else
         Attenuation = 0.0;
Bill P.
Aside: I moved pow to powf as the latter often much faster and float
accuracy is fine for attenuation. It might be official releases are
already running 'pow()' with floats without code that forces it.
