POV-Ray : Newsgroups : povray.beta-test : v3.8 beta 2 seg fault. 32 bit raspbian os on 64 bit pi 4 hardware. : Re: v3.8 beta 2 seg fault. 32 bit raspbian os on 64 bit pi 4hardware. Server Time
10 Nov 2026 22:54:11 EST (-0500)
Date: 5 Oct 2021 16:28:49
Message: <615cb581$1@news.povray.org>
On 8/27/21 5:04 AM, William F Pokorny wrote:
> On 8/26/21 3:19 PM, William F Pokorny wrote:
>> The code there has a hard LL literal assuming long long int is 64 bits.
> Blast it, I meant to write:
> "The code there has a hard LL literal assuming POV_LONG is 64 bits."
> With C++11 'long long int' and 'unsigned long long int' are always at
> least 64 bits.
In working on documentation for my povr branch changes I noticed the
issue here is essentially github issue #384.
"vfesession.cpp:342 overflow in conversion from long long int to
long int on m68k #384"
https://github.com/POV-Ray/povray/issues/384
I've for a month or so in those handful of configuration files simply
had the lines:
// C++11 required. We can set following macros directly.
#define POV_LONG  std::int_least64_t
#define POV_ULONG std::uint_least64_t
over the conditional logic which was there.
This looks to be what clipka recommended in responding to #384.
Bill P.
