POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-beta 1 - Parse error using "%s" in Win10 : Re: POV-Ray v3.8.0-beta 1 - Parse error using "%s" in Win10 Server Time
10 Nov 2026 11:05:57 EST (-0500)
Date: 11 Aug 2021 17:55:43
Message: <6114475f@news.povray.org>
Am 11.08.2021 um 22:37 schrieb William F Pokorny:
>    #debug concat("%z ---> <",datetime(now,"%z"),">\n")
>    #debug concat("%Z ---> <",datetime(now,"%Z"),">\n")
>    // For the lines above
>    // 3.7.0.8  - Invalid formatting code in format string, or
>    //            resulting string too long.
>    // v3.8 b 1 - Invalid formatting code in format string, or
>    // ~master  - Invalid formatting code in format string, or
>    // povr     - %z ---> <-0400>
>    //            %Z ---> <EDT>
Hah!
This one took me a while, and I was on the verge of asserting that
`strftime` must be broken on your machine. Because whatever `strftime`
does, it should NOT be reporting an error when confronted with these
parameters.
The kicker is: It doesn't.
What happens it that - for _some_ reason - `strftime` can't properly
determine the time zone (e.g. because it doesn't know whether DST is in
effect or not).
In that case, it is contractually obliged to replace `%z` or `%Z` with
an empty string.
Which, in this very special case, leads to a completely empty result string.
Which means that `strftime` return a value of 0, because that's what it
does if it doesn't encounter a fatal error: It returns the number of
characters placed in the result string.
Zero.
Which also happens to be the value it is contractually obliged to return
if it runs out of space to write the result string to.
So POV-Ray panics, imagining there to be a serious problem when there is
none.
>    #debug concat("%z ---> <",datetime(now,"%c %z"),">\n")
>    #debug concat("%Z ---> <",datetime(now,"%c %Z"),">\n")
>    // 3.7.0.8  - %z ---> <Wed 11 Aug 2021 07:58:53 PM  >
>    //            %Z ---> <Wed 11 Aug 2021 07:58:53 PM  > (**)
>    // v3.8 b 1 - %z ---> <Wed 11 Aug 2021 07:58:53 PM  >
>    // ~master  - %z ---> <Wed 11 Aug 2021 03:05:50 PM  > (***)
>    //            %Z ---> <Wed 11 Aug 2021 03:05:50 PM  > (***)
>    // povr (*) - %z ---> <Wed 11 Aug 2021 03:05:50 PM EDT -0400>
>    //            %Z ---> <Wed 11 Aug 2021 03:05:50 PM EDT EDT>
> // (*) The time isn't accounting for dst though %z,%Z correct.
> // (**) The %c should include a %Z string of its own and does not.
Should it though?
The C (and by extension C++) standard mandates that `strftime` replace
`%c` with "the locale’s appropriate date and time representation".
That's it, no other specification for it. Whether that is to include any
time zone information is, I would argue, up to "the locale". For the `C`
locale, for instance, the standard specifically mandates that a timezone
specifier is NOT included in the "%c" replacement text.
Also, even if the locale does happen to include a `%Z`, it makes sense
that it also gets replaced by an empty string, just like an explicit `%Z`.
> // (***) Above issue and time not the actual utc time.
Not at all surprised there.
Should match your local non-DST time.
> As I believe I mentioned somewhere else, I'm not sure what all doesn't
> work with respect to formatting given the boost code being used doesn't
>   set up all the fields needed to use the complete set of strftime()
> formatting.
 From all of my understanding, only the timezone identifier (either
explicitly, or implicitly such as via `%c`) should suffer.
Okay, I guess the takeway lesson here is that as implemented up to (and
including) v3.8.0-beta-1, your system doesn't seem to have enough
information to decide what timezone is applicable, presumably because
the info whether DST is in effect for the date isn't explicitly set, and
your runtime library's `strftime` function does not make any attempt to
figure it our for itself.
Which begs the question, what exactly does povr do differently?
