POV-Ray : Newsgroups : povray.beta-test : `datetime(now)` issue - suggestions for a solution : Re: `datetime(now)` issue - suggestions for a solution Server Time
12 Nov 2026 23:53:37 EST (-0500)
Date: 9 Aug 2021 07:33:01
Message: <6111126d$1@news.povray.org>
Am 09.08.2021 um 12:53 schrieb jr:
> a better suggestion would have been:
>    [locale]
>    tz = {local|utc}
>    lang = en_GB.utf8
> as you say, conf provides environment type info.  given that 'strftime()' uses
> locale, a setting to provide a preference/default could be useful.  (POV-Ray
> appears to use the locale already, anyway)
No, that's not really it.
You don't need to tell POV-Ray whether your system HAS a time zone or
not. Because your system DOES, period. Even if that timezone happens to
be UTC.
In the context of the issue, you have to tell POV-Ray whether you want
to operate in the context of that time zone, or rather prefer to operate
in a context that is universal across time zones.
And that doesn't differ based on what system you're running POV-Ray on.
It differs based on what you want to do with POV-Ray.
As for specifying _details_ about the locale, such as the actual time
zone, language or whatnot, that isn't much of a thing either. Your
system has a default locale, and there's a standard interface for making
use of that. And there's little to no point in using a different one for
POV-Ray (except possibly on a per-scene basis, but in that case
`povray.conf` wouldn't be the right place anyway).
>> Also, it is definitely a setting that individual scenes should be able
>> to override. ...
> sure, thought setting a convenient default, and override in 'datetime()'s second
> arg, if required.
As I said, the INI file mechanism would be the way to go for such purposes.
