POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-beta 1 - Parse error using "%s" in Win10 : Re: POV-Ray v3.8.0-beta 1 - Parse error using "%s" in Win10 Server Time
12 Nov 2026 22:07:13 EST (-0500)
Date: 31 Jul 2021 04:18:55
Message: <6105076f$1@news.povray.org>
On 7/30/21 7:13 PM, clipka wrote:
> Am 30.07.2021 um 23:38 schrieb Cousin Ricky:
>>> I realize only now that I accidently implemented the wrong behavior
>>> (judging by the documentation, and intent so far).
>> The 3.8 documentation say 'now' should return GMT, and on my GNU/Linux
>> box, it (pre-beta) does return UTC or GMT.  Are you proposing a change
>> in behavior?
> I think I do, yes.
> The current behavior appears to be quite inconsistent across platforms
> and systems and whatnot.
Cousin Ricky is onto something; Me screwing up with respect to v3.8 beta
1 results. :-(
I maintain "many" versions of POV-Ray which I run with wrapper scripts
that are careful to strip any $HOME directory or environment variable
customizations - so I'm always testing the native code and set up.
When I grabbed and compiled:
https://github.com/POV-Ray/povray/releases/tag/v3.8.0-beta.1
I created a 'p380b1' wrapper script, but I screwed up and pointed it to
the v3.8 compile directories for the commit from off of which I'm basing
my povr stuff. All my testing of v3.8 beta 1 over the last couple weeks
has been against something closer to the current master branch.
#@%^$^%$&!!! The version is clearly there in the text output, which I
ignore 99.99% of the time...
What this means is the 'now' command I was running as v3.8 beta 1 was
the newer(1) c++11 version. It's that one not returning the utc/gmt/zulu
time making the default 'Z' format suffix wrong.
(1) - Though I've been running primarily that one for years - so I was
seeing what I expected to see as datetime(now) output.
I think, Christoph, an option - if you want to minimize v3.8 release
change - would be to let things go as they are. This would mean a hard
UTC datetime() result without working %z and %Z format options (others?).
I agree with your thinking the behavior of 'now' should updated, but
this could be delayed to v4.0.
Bill P.
