POV-Ray : Newsgroups : povray.beta-test : spline in, out array bug : Re: spline in, out array bug Server Time
17 Mar 2026 19:07:57 EDT (-0400)
Date: 15 Jul 2021 07:29:03
Message: <60f01bff$1@news.povray.org>
On 7/15/21 5:54 AM, ingo wrote:
> In the scene below is spline is defined and then put into an array. When
> it is pulled out of the array it always is a linear spline, instead of
> the original 'curvy' spline. This used not to be the case as one of the
> meshmaker macro's depends on doing this since 3.5.
> I cannot trace back where this behaviour originated as I only have 3.8
> alpha's and beta's here and all show this behaviour. (running win10)
> #version 3.8;
> global_settings {assumed_gamma 1.0}
> camera {location <0,3.5,-12> look_at <0,1.5,0> angle 40}
> light_source {<500,500,-500> rgb <0.8,0.9,1>}
> #declare A1=spline {
>     cubic_spline
>     -0.5, < 1,-1, 0>
>      0.0, < 1, 0, 0>
>      0.5, < 2, 1, 0>
>      1.0, < 1, 2, 0>
>      1.5, < 1, 3, 0>
> #declare An=array[1]{
>     spline{A1},
> #declare M=500;
> union {
>    #declare Spl=spline{An[0]};
>    #for(I,0,50)
>     sphere {Spl(I/50), 0.04 no_shadow pigment {rgb 1}}
>    #end
Looks like a problem with spline{} block parsing when passing a spline
id. The current Parse_Spline() code expects the spline type token to
exist otherwise it assumes the intent was a linear spline.
A fix is to add some dynamic_cast 'type checking' to:
GenericSpline *Parser::Parse_Spline()
in parser_expressions.cpp so it looks something like:
     if (!New)
         if (Old)
             if (dynamic_cast<LinearSpline *>(Old)!=nullptr)
                 New = new LinearSpline(*Old);
             else if (dynamic_cast<QuadraticSpline *>(Old)!=nullptr)
                 New = new QuadraticSpline(*Old);
             else if (dynamic_cast<CatmullRomSpline *>(Old)!=nullptr)
                 New = new CatmullRomSpline(*Old);
             else if (dynamic_cast<NaturalSpline *>(Old)!=nullptr)
                 New = new NaturalSpline(*Old);
             else
                 throw POV_EXCEPTION_STRING("Internal Error. Pointer to
existing spline not of a known type.");
//          New = new LinearSpline(*Old); // <-- what is done currently.
         else
             New = new LinearSpline();
Bill P.
