POV-Ray : Newsgroups : povray.beta-test : Parsing issue. Density and blend_mode, blend_gamma. : Re: Parsing issue. Density and blend_mode, blend_gamma. Server Time
9 Nov 2026 02:16:21 EST (-0500)
Date: 10 Feb 2021 14:20:48
Message: <60243210$1@news.povray.org>
On 2/10/21 2:50 AM, Thomas de Groot wrote:
> Op 09/02/2021 om 14:04 schreef William F Pokorny:
>> This fails to parse:
> Says: "Must have at least one color in color map"
> Strange.
> Otherwise, this is a nice feature which I had not been aware of (or
> forgot about; so many features in POV....)
Yes & yes.
Chased this one for most of the day - and still not got it.
For reasons still a mystery, it appears the issue is with just
'blend_gamma'. If you you specify only blend_mode everything is OK. You
can change blend_mode with no issue.
For some reason the blend_gamma token is not getting picked/seen up when
specified inside the density (or maybe media) block - that is the real
error despite the message.
I usually define my maps stand alone (this not an issue for me basically
in normal work flow) so I wondered how general the issue. Only tested
color_maps defined within a pigment - and there blend_gamma works as
expected.
Complicating things some, there is code for the color map parsing apart
from all other map parsing due trying to maintain compatibility with
some aspect of v1.0 of POV-Ray. I'll probably dump that special version
in the povr branch - if I an work out how.
In any case, this is starting to look like some sort of deeper parser
issue. At the moment I'm baffled.
Bill P.
