On 2/3/19 10:35 AM, William F Pokorny wrote:
> On 2/3/19 4:04 AM, clipka wrote:
>> Am 17.01.2019 um 15:05 schrieb William F Pokorny:
>>>> - Performance has degraded a bit, but I'm willing to accept this for
>>>> the sake of extended functionality and easier maintenance.
>>> Hmm, I'm surprised some by this. Are your test character strings
>>> really short? In the existing text shape code all the characters
>>> ended up more or less as one huge glyph as you know. As the string to
>>> the text shape got large, performance slowed substantially.
>> Actually, wading through the old code for unrelated reasons, I just
>> noticed that this isn't true: The old `text` primitive has actually
>> been a CSG union all along, with one child per character.
> Hmm. Not my recollection or experience. I was focused on inside tests if
> those were perhaps done differently than intersections. The glyph loop
> range testing I added helped regular intersection performance too, but
> less.
Trying to avoid sliding too much sideways into work I did almost two
years ago given I've already got more going than I'll ever finish. Can't
completely help it I guess. Over the past days, kept asking myself how
could I see such large performance improvements if the text object was
already a union (Christoph and Alain being almost certainly right).
- Remembered two years ago I was mostly going after performance using
hardware counter analysis. I was going after hot spots.
- Remembered a decade ago with the objectAsIso experiments how I looked
hard at converting other than the simplest csg to a mesh because the
inside test performance got so slow with larger/complex csg.
- Remembered Lanuhum's Blender hair scene and thinking it shouldn't
really be that slow, even with super slow sphere_sweeps.
- Remembered thinking on trying it years ago the +bm2 mode should
provide more performance than it does.
- Remembered learning early last year while finding the cause of a
particular speckling bug, that POV-Ray does inside tests when it creates
original rays.
- Remembered thinking fixes to that particular speckling bug and issues
like: https://github.com/POV-Ray/povray/issues/139 will likely require
multiple inside tests over one to account for floating point noise no
matter any improved accuracy.
These last two thoughts led me to doing a new performance test with our
ttf1.pov sample scene. One where all I changed was whether or not AA
used. My thinking is the performance improvement of my text branch
should be more or less the same with and without AA. It should be the
same, unless, the text object is a union and the real performance
problem is the csg inside test mechanism doing something like just
trundling through ALL the shapes in a csg.
Results were not similar. This leads me to a new suspicion / unproven
theory we are sitting on a csg inside test performance issue. One
perhaps affecting things generally. My code changes to the text object
only treated another problem.
I've spent zero time in the csg code and I'm working/playing elsewhere
for the foreseeable future. I'm put digging here on my, maybe, someday
list - for what little that's worth! My new theory is perhaps wrong too
- but there is something going on inside test wise which is not very
efficient.
Aside: Even looking at single shapes of a type, the inside test
performance is often awful. This is why that isosurface peeling paint
skin test of Thomas's superellipsoid using the hard/soft object patch
was so extremely slow. IIRC, a box replacement was more than 20x faster.
Bill P.
--------------------------- Data for those interested.
/usr/bin/time povray ttf1.pov +am2 +a0.1 +r4 +wt1 \
-j -cc -fn -d -p +w2000 +h2000
p380
12.39user 0.04system 0:12.71elapsed With +a0.1
12.21user 0.03system 0:12.51elapsed
12.27user 0.03system 0:12.56elapsed
36.87
4.40user 0.03system 0:04.70elapsed With -a0.1
4.36user 0.05system 0:04.65elapsed
4.40user 0.02system 0:04.66elapsed
13.16
p380 + my text shape branch
12.08user 0.04system 0:12.40elapsed With +a0.1
12.08user 0.04system 0:12.36elapsed
12.18user 0.03system 0:12.45elapsed
36.34 -1.44%
4.39user 0.01system 0:04.64elapsed With -a0.1
4.32user 0.04system 0:04.59elapsed
4.34user 0.03system 0:04.64elapsed
13.05 -0.84% (??? Hmm)
----------- Repeating a few previous perf tests for my text branch.
soft_object.pov p380 + hard/soft object only.
345.96user 0.08system 5:46.50elapsed As 'text union'
64.91user 0.04system 1:05.52elapsed Individual chars at top (-81.24%)
soft_object.pov p380 + hard/soft object + my text shape branch.
161.22user 0.05system 2:41.78elapsed As 'text union' -53.40%
69.42user 0.02system 1:09.99elapsed Individual chars at top (+6.95%)
