POV-Ray : Newsgroups : povray.beta-test : Front end cannot process .ini files : Front end cannot process .ini files Server Time
12 Nov 2026 01:17:18 EST (-0500)
Date: 4 Nov 2018 17:41:47
Message: <5bdf75ab$1@news.povray.org>
POV-Ray 3.8 cannot process .ini files in my library path; I have to
provide the path to the .ini file in order to get a successful render.
For example:
My povray.ini contains:
---------- [BEGIN FILE EXCERPT] ----------
Library_Path="/usr/local/share/povray-3.8"
Library_Path="/usr/local/share/povray-3.8/ini"
Library_Path="/usr/local/share/povray-3.8/include"
Library_Path="/home/ricky/Documents/POV-Ray/include"
Library_Path="/home/ricky/Documents/POV-Ray/include-others"
Library_Path="/home/ricky/Documents/POV-Ray/Object_Collection"
Library_Path="/home/ricky/Documents/POV-Ray/LightsysIV"
Library_Path="/usr/share/fonts/truetype"
Library_Path="/home/ricky/.fonts"
----------- [END FILE EXCERPT] -----------
These paths are confirmed in the message window of a successful render.
Directory /home/ricky/Documents/POV-Ray/include, which is in the library
path, contains the file:
   jpeg.ini
Directory /home/ricky/Documents/POV-Ray/plane contains the file:
   myscene.pov
 From /home/ricky/Documents/POV-Ray/plane I run the command:
   povray-3.8 myscene.pov jpeg
("povray-3.8" is what I renamed the 3.8 executable, as I still default
to POV-Ray 3.7.0.)
The command fails with the message:
---------- [BEGIN ERROR MESSAGE] ----------
Problem with option setting
Failed to parse command-line option
----------- [END ERROR MESSAGE] -----------
This command renders without errors:
   povray-3.8 myscene.pov ../include/jpeg
This problem has existed since the POV-Ray 3.7.1 betas, and is present
in the latest UberPOV.  Previous versions of POV-Ray do not have this
problem.  (Earlier, I reported a failure to process certain .ini files
from within their own directory; that problem no longer occurs.)
There is no problem locating #include files from within a scene file.
POV-Ray version: 3.8.0-alpha.9893777.unofficial (g++ 7 @
x86_64-pc-linux-gnu)
OS: openSUSE Leap 15.0 (GNU/Linux)
