POV-Ray : Newsgroups : povray.beta-test : 3.7.0RC3 -- make check -- how long should the test run? : Re: 3.7.0RC3 -- make check -- how long should the test run? Server Time
27 Mar 2026 23:55:17 EDT (-0400)
Date: 22 Jun 2011 04:35:16
Message: <4e01a944$1@news.povray.org>
Le 21/06/2011 21:30, clipka a écrit :
> Am 21.06.2011 20:36, schrieb Le_Forgeron:
>> I wonder a bit about the construct
>>         while ( !Stream.eof() )
>>             // get and preprocess line
>>             std::getline(Stream, line);
>>             line = pre_process_conf_line(line);
>>             ++line_number;
>>             // skip empty line
>>             if(line.length() == 0)
>>                 continue;
>> If the last line is length 0, would the eof() be evaluated (again) ?
> The C/C++ language construct
>     while ( <CONDITION_1> )
>         <STATEMENTS_A>
>         if ( <CONDITION_2> ) continue;
>         <STATEMENTS_B>
> is fully equivalent to
>         <STATEMENTS_A>
>         if ( ! <CONDITION_2> )
>             <STATEMENTS_B>
Ok, thanks for the check. So that (i.e. loop with continue not detecting
the end of file) was a red herring.
In the meantime, I compiled on a Red Hat Server 6.1 /x86_64, and it
works fine too (once I installed boost
 and add the infamous --with-boost-thread=boost_thread_mt to configure)
(It's boost 1.41)
Alas, I have no Suse available.
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
