POV-Ray : Newsgroups : povray.beta-test : 3.7.0RC3 -- make check -- how long should the test run? : Re: 3.7.0RC3 -- make check -- how long should the test run? Server Time
29 Mar 2026 02:53:19 EDT (-0400)
Date: 21 Jun 2011 14:36:31
Message: <4e00e4af@news.povray.org>
Le 21/06/2011 17:30, Jan-Philip Gehrcke nous fit lire :
> [Thread debugging using libthread_db enabled]
> [New Thread 0x2b98e31c7950 (LWP 4278)]
It can be interesting to look also at that thread too, as it might have
the mutex the main thread is expecting.
gdb command would be "info threads"
then "thread <number_of_the_thread_for_gdb>"
and "where" once there.
> 0x00002b98df0fb5fd in pthread_mutex_lock () from /lib64/libpthread.so.0
> (gdb) where
> #0  0x00002b98df0fb5fd in pthread_mutex_lock () from /lib64/libpthread.so.0
> #1  0x00002b98dec492a2 in ?? () from /lib64/ld-linux-x86-64.so.2
> #2  0x00002b98e151e552 in std::basic_istream<char, std::char_traits<char> >&
> std::getline<char, std::char_traits<char>, std::allocator<char>
>> >(std::basic_istream<char, std::char_traits<char> >&, std::basic_string<char,
> std::char_traits<char>, std::allocator<char> >&, char) () from
> /usr/lib64/libstdc++.so.6
> #3  0x0000000000430bd0 in vfePlatform::UnixOptionsProcessor::parse_conf_file (
>     this=0x92f7b0, Stream=@0x7fffb8f87850, conf_name=@0x92f7d8, user_mode=true)
>     at unix/unixoptions.cpp:817
> #4  0x0000000000431fe7 in vfePlatform::UnixOptionsProcessor::process_povray_conf
> (this=0x92f7b0) at unix/unixoptions.cpp:1052
> #5  0x0000000000432768 in UnixOptionsProcessor (this=0x92f7b0,
>     session=<value optimized out>) at unix/unixoptions.cpp:195
> #6  0x000000000042b000 in vfeUnixSession (this=0x92f2a0,
>     id=<value optimized out>) at unix/vfeplatform.cpp:133
> #7  0x000000000043e141 in main (argc=10, argv=0x7fffb8f881e8)
>     at unix/unixconsole.cpp:452
> (gdb)
It could be interesting to up to #3 to get more information about Stream
(and line_number of unixoptions.cpp... parse_conf_file() )
For the time-being, it looks like a mutex-lock for that thread, done by
the system itself.
Are you somehow on a NFS mounted filesysem ? (like "your home is mounted
everywhere, whatever the system you log in" ?)
I'm used to --disable-io-restrictions for configure, you might give it a
try (at least for the experiment).
I wonder a bit about the construct
		while ( !Stream.eof() )
			// get and preprocess line
			std::getline(Stream, line);
			line = pre_process_conf_line(line);
			++line_number;
			// skip empty line
			if(line.length() == 0)
				continue;
If the last line is length 0, would the eof() be evaluated (again) ?
