POV-Ray : Newsgroups : povray.beta-test : QR command line option : Re: QR command line option Server Time
24 Mar 2026 14:25:42 EDT (-0400)
Date: 14 Nov 2009 14:24:12
Message: <4aff03dc$1@news.povray.org>
John Coppens schrieb:
> Hello people.
> I was trying to get kpovmodeler to use 3.7beta, and thought I was there.
> But then I got a command-line problem. It seems 3.7 doesn't accept +QR as
> an option anymore (does it?).
> Kpovmodeler always seems to generate +(or -)QR, so this means some patch
> to the source code...
> I couldn't find any reference to the QR flag in the changelog. Is this
> change documented somewhere?
That switch has been deprecated for years, at least since 3.6, which
doesn't even mention it in its documentation, and just gracefully ignore
it with the following warning:
     Radiosity commandline/INI switch is not needed in POV-Ray 3.5.
     Add a radiosity{}-block to your scene to turn on radiosity.
Unfortunately, it will only output this message if the parameter is
turned /off/, so some pepople may not have been warned about it.
