POV-Ray : Newsgroups : povray.beta-test : Subset_Start_Frame doesn't work? : Re: Subset_Start_Frame doesn't work? Server Time
13 Feb 2026 00:07:01 EST (-0500)
Date: 3 Nov 2006 12:34:41
Message: <454b7db1@news.povray.org>
FurBall wrote:
> When I render an animation using an INI-file that contains the following
> lines:
>    Final_Frame=675
>    Subset_Start_Frame=125
>    Subset_End_Frame=276
> I get frames 1 through 276, instead of 125 through 276.
> Apparently, Subset_Start_Frame does not work and Subset_End_Frame does.
> Same behaviour when I use +SF125.
> Same behaviour when I use the commandline.
> Am I missing something?
Confirmed, seems I missed that when fixing the Initial_Frame problem. Will be
fixed in next beta.
-- Chris
