POV-Ray : Newsgroups : povray.beta-test : Parser Statistics, empty ini : Parser Statistics, empty ini Server Time: 21 Mar 2010 16:58:52 GMT
Date: 1 Apr 2006 03:22:02
If I have a scene with fewer objects than the Bounding_Threshold, I get the
following stats.
Finite Objects are not counted.
Infinite Objects are counted under Finite Objects
Light Sources are counted under both Light Sources and Finite objects
If I equal or exceed the Bounding_Threshold all is well.
If I try to render an empty ".ini" file. WinPOV tells me "No source file
specified..." (correct) but the Run icon remains as the Stop icon. Pointing
WinPOV to a valid file and clicking the (now) Stop icon runs the file.
Clicking on the menu " file/exit" does nothing, using "alt+x" or the "close"
button in the upper right hand corner correctly exits WinPOV.
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
