POV-Ray : Newsgroups : povray.beta-test : Heightfield bug (most probably an inverted normals problem) : Re: Heightfield bug (most probably an inverted normals problem) Server Time
23 Mar 2026 23:09:42 EDT (-0400)
Date: 21 Jan 2002 18:54:38
Message: <3c4caa3e@news.povray.org>
Let me guess the reason for this: When povray calculates the ray-hf
itersection, it returns the normal inverted if the regular normal was at
an angle <90 degrees with respect to the incoming ray.
  There might be some archaic reason for this and it doesn't matter with
non-smooth heightfields, but it causes a misbehaviour when a smooth triangle
is oriented so that it faces the camera but some of its normal vectors are
pointing away from it.
