POV-Ray : Newsgroups : povray.beta-test.binaries : A Unix script and a few sample scenes Server Time
16 Jun 2024 22:21:10 EDT (-0400)
  A Unix script and a few sample scenes (Message 1 to 4 of 4)
Subject: A Unix script and a few sample scenes
Date: 12 Sep 2019 17:22:32
Message: <8736h1fbvy.fsf@sp.am>
I’ve recently installed POV-Ray 3.7 for Unix, and one of the first
things I did afterwards was to run the scripts “allanim.sh”,
“allscene.sh” and “portfolio.sh” to generate HTML documents showcasing
the ray tracer’s capabilities.  I ran into the “reflection.ini” issue
reported by ThH nearly four years ago, as well as a few that don’t seem
to have been mentioned or fixed anywhere.  The attached archive contains
the following files edited by me from the ones in the 3.7.0 release.
Maybe I should have used the 3.8.0 ones instead, but I’ve read
_somewhere_ that branch has been more or less abandoned.
• povray/unix/scripts/allscene.sh
The calling conventions detailed in the comments specify eight possible
arguments, but the script only took six into account, ignoring the rest.
I noticed the problem when the script failed to make an HTML file.
• povray/distribution/scenes/animations/float2/float2.pov
Missing “equals” sign in the text object showing the ‘inc’ function.
• povray/distribution/scenes/animations/float4/float4.pov
In the text object, “atan2(B,C)” should be “atan2(B,A)”, which is the
value actually calculated.
• povray/distribution/scenes/portfolio/allobjects.pov
The macro ‘Sphere_Of_Spheres’ created two coïncident copies of each of
the spheres lying on either of the two first meridians, and did not
check that there was enough room around the poles.  For instance, in
this scene itself, there were two spheres very visibly colliding at the
pole facing the viewer.
I’ve included two images made with the original macro and the fixed one,
in the “allobjects_images” folder.  In the latter, you need to pay very
close attention to notice the pole at all, revealed only by the slightly
wider space around one sphere, which already happened anyway when a
parallel’s length is close to allowing an extra sphere, but not quite
there.
• povray/distribution/scenes/portfolio/readme.txt
Repeated word _and_ in the third line (second non-empty one).
Download 'edited-script-and-scenes.7z.zip' (564 KB) Download 'us-ascii' (1 KB)
Subject: Re: A Unix script and a few sample scenes
Date: 13 Sep 2019 11:07:43
Message: <5d7bb0bf@news.povray.org>
Updates of the kind outlined are made only in the master, v3.8
branch(1). Compile related issues cropping up over time have been fixed
in the v3.7 stable branch since release - buts that's it. Linux package
providers are at v3.7 only as far as I know.
I agree with the changes you've made with regards to updating the v3.8
branch. The allscene.sh update will need to be merged with what's in the
master branch as it has otherwise changed.
I'll create a branch with your fixes and open an issue so they won't be
forgotten.
The reflection.ini update was made in the master branch very shortly
after ThH's posting.
Bill P.
(1) - My understanding is it was the (got to beta something) v3.71
release which was dropped for a v3.8 one. The action coming after a few
users pointed out the changes more accurately represented another
substantial update and not a patch release to v3.7.
Date: 14 Sep 2019 07:31:11
Message: <5d7ccf7f$1@news.povray.org>
> forgotten.
See:
https://github.com/POV-Ray/povray/issues/382
Bill P.
Date: 15 Sep 2019 15:19:27
Message: <87o8zl74g1.fsf@sp.am>
Thank you very much.
