POV-Ray : Newsgroups : povray.beta-test.binaries : Function / pattern issues. New inbuilt f_bump(). Server Time
16 Jun 2024 22:08:37 EDT (-0400)
  Function / pattern issues. New inbuilt f_bump(). (Message 1 to 1 of 1)
Subject: Function / pattern issues. New inbuilt f_bump().
Date: 13 Jun 2020 10:01:47
Message: <5ee4dc4b$1@news.povray.org>
<---------------------- References. Eleven previous posts
http://news.povray.org/povray.beta-test.binaries/thread/%3C5ec3f269%241%40news.povray.org%3E/
and
http://news.povray.org/povray.beta-test.binaries/thread/%3C5ee4b9e3%40news.povray.org%3E/
In povr adding a new helper function in f_bump(). Not meant to be run
stand alone but rather to bump (displace) a surface - or field - using a
base function. In the attached image 4 examples displacing the surface
of a plane where the base function is a cylinder. The bottom row a
displacement on a sphere on left and a displacement of a 'field'
provided by the torus to create the inner shape.
#declare Fn01r = function (x,y,z) { sqrt(x*x+z*z) }
#declare Fn01 = function (x,y,z) {
     y - f_bump(Fn01r(x*5,y,z*1),8,0)*0.5
#declare Iso99 = isosurface {
     function { Fn01(x,y,z) }
f_bump()
Parameters:
1. Input value as provided by a base function.
2. Power of 2.0 exponent integer multiplier. For the typical rounded
dome use 1.0. Higher values tend to square off or sharpen the result. Up
to 20 usually OK.
3. If 0, the value is returned straight up which means the maximum value
is ~= 0.3679.  If 1, return value is normalized to 0 to 1 range. If 2,
the return value is normalized to a -1 to 0 range or a 0 to 1 range
depending upon input polarity.
Notes. The bump function 'bumps' values > -1 and < 1. Other input values
are ignored.
Bill P.
Download 'story_f_bump.jpg' (46 KB)
Preview of image 'story_f_bump.jpg'
