POV-Ray : Newsgroups : povray.beta-test.binaries : Function / pattern issues. Updated f_ellipsoid(). New f_lame,... Server Time
16 Jun 2024 21:02:32 EDT (-0400)
  Function / pattern issues. Updated f_ellipsoid(). New f_lame,... (Message 1 to 1 of 1)
Subject: Function / pattern issues. Updated f_ellipsoid(). New f_lame,...
Date: 15 May 2020 09:20:06
Message: <5ebe9706$1@news.povray.org>
<---------------------- References. Eight previous posts
http://news.povray.org/povray.beta-test.binaries/thread/%3C5ead9027%40news.povray.org%3E/
and
http://news.povray.org/povray.beta-test.binaries/thread/%3C5eb4b9c6%241%40news.povray.org%3E/
Updating the inbuilt f_ellipsoid() function. Adding new f_lame() and
f_polyhedron() functions.
The f_ellipsoid function was one of those with it's threshold / roots up
a 1.0. It also specified the scaling as inverse values. It's now a 0.0
centered ellipsoid function with expected a,b,c scaling. Also brought
out the exponential value to get some superellipsoid functionality on
the cheap. Two of the latter sort of super forms shown in the top two
rows of the attached image.
The new f_lame (1) and f_polyhedron functions are ways to create n faced
objects by passing in axis aligned gradients (and/or using x,y,z). The
latter is a subset of the former's result, but faster if you only want
flat faces. Results from f_polyhedron in the lower left and f_lame in
the lower right of the attached image with the same 5 input gradients.
(1) Yes the e should be accented in f_lame, but wimped out on having
that character in the code. Interesting to me is Lamé's work seems to be
underneath a lot of the super__oid stuff.
In other than the f_polyhedron implementation, I'm also playing with the
ability for the user to specify additional internal sqrt()s to reduce
the gradients. So long as the equations set up as "<calculated> - 1.0 =
0.0" this works well in my testing. It becomes another performance trade
off used over just increasing the gradient. As important, it's a method
to bring the gradients down toward 1.0 where the inbuilt function values
play well with other functions and patterns.
------- f_ellipsoid
Parameters: x, y, z
Five extra parameters required:
1. If 0, calculations are done with double floats. Otherwise with single
floats. The latter often a lot faster with not much loss in accuracy.
2. x scale
3. y scale
4. z scale
5. The pow() exponent to use. For a proper ellipsoid use 2.0. For an
octahedron use 1.0. For an inward curvature from axises use values <
1.0. For Rounded box to round use values >2.0. The exponent here not
locked at 2.0 offers a subset of results like that of the superellipsoid
at less compute expense.
6. The number of times to take the sqrt() internally to reduce the
gradient.  1 a good starting point. Usually more than 2 not worth it. 0
for very round results works fine.
Notes. Previously f_ellipsoid() only worked for isosurfaces of threshold
1.0 and the axis scaling was inverted. In other words, it was not a
general function thought relatively fast. Changed in povr May 14, 2020
to align with standard root/threshold behavior.  Further, extended to
pass exponent as this enables some f_superellipsoid results at a much
lower compute cost.
---------- f_polyhedron
Parameters: x, y, z as x, y z or passed f_gradient()s on arbitrary
axises. 13 parameters required:
1. Count of input gradients. 3 to use only x,y,z.
2-13. Up to 12 input axis gradients. See f_gradient function, but any
value input method allowed.
Notes. When using x,y,z or f_gradient() the gradients are projected onto
normalized input vectors. This is useful because it often allows for
some normalization of the scaling.
#declare normScale = 3/(2*<additional_gradients>)
f_polyhedron(x*normScale,y,z*normScale,5,
              f_gradient(-1,0,1)*normScale,0,0,0,
              0,0,0,0,
              0,0,0,0)
------------ f_lame
Parameters:
1. Number of input gradients.
2. If 0 does calculations as doubles, otherwise as floats for
performance less accuracy.  Here whether floats help depends a lot of
the exponents. Mixed 0.6 to 1.6 on 5 gradients 31.019 -> 28.882 --->
-6.89% going to single floats.
3. The number of times to take the sqrt() internally to reduce the
gradient.  Using 1 a good starting point. Usually more than 2 not worth
it. 0 for very round results works fine.
4-11. One to eight input gradient values.
12-19. One to eight matching pow() exponent values.
Notes. If all exponents ==1, look at more efficient f_polyhedron
alternative. Generally if exponents are <1.0 introduces an inward /
concave curvature. If 1, flat faces, If >1 outward / convex curvature.
See f_polyhedron comments on normalized scaling with x,y,z projects onto
normalized vectors.
----------------- Code snipets
#declare Iso99 = isosurface {
     function { f_ellipsoid(x,y,z,1,0.3,0.9,0.6,4.4,1) }
#declare nrmScl = 3/7;
     function { f_polyhedron(x*nrmScl,y*2,z*nrmScl,5,
             f_gradient(x,y*2,z,-1,0,-1)*nrmScl,
             f_gradient(x,y*2,z,-1,0,+1)*nrmScl,0,0,
             0,0,0,0,
             0,0,0,0)
     function { f_lame(5,1,2,
             f_gradient(x,y*2,z,-1,0,+1)*nrmScl,0,0,0,
             0.7,1.0,1.3,1.6,0.6,0,0,0)
Lastly, not sure I've anywhere mentioned adding the povr f_gradient()
inbuilt used here. It replaces the three, fixed axis, pattern wrapped
ones in functions.inc with one which has 3 additional parameters to
specify the axis onto which to project (now like the pattern version).
Opens up another transform-ish like capability for all functions; though
admit it's a new knob where I've not played much yet.
Bill P.
Download 'storyfellipse_fpolyhedon_flame.png' (74 KB)
Preview of image 'storyfellipse_fpolyhedon_flame.png'
