POV-Ray : Newsgroups : povray.beta-test.binaries : Incorrect image height in output file (with +SR/+ER options) Server Time
9 Jun 2026 11:30:42 EDT (-0400)
  Incorrect image height in output file (with +SR/+ER options) (Message 1 to 3 of 3)
Subject: Incorrect image height in output file (with +SR/+ER options)
Date: 10 May 2004 05:40:00
Message: <409f4df0$1@news.povray.org>
The result of the following command "povray +W100 +H100 +SR0 +ER50 +FP
+Otest.ppm test.ini" is an incorrect image.
The header of the PPM file is:
P6
100 100
255
but it includes only 50 rows. The height of the image file should be 50
instead of 100.
Thanks,
David Bucciarelli
Subject: Re: Incorrect image height in output file (with +SR/+ER options)
Date: 10 May 2004 05:55:02
Message: <c7njdv$42a$1@chho.imagico.de>
> P6
> 100 100
> 255
> instead of 100.
This is as intended, otherwise you could not append to the image file in
a continued trace.  Also it has been this way in all previous versions
of POV-Ray and not just 3.6.
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 10 May 2004 08:03:57
Message: <409f6fad@news.povray.org>
>> P6
>> 100 100
>> 255
>> 50 instead of 100.
Mmmm, I understand your point however it is strange behavior because
opening the "test.ppm" file with xv, gimp or Java ImageIO API fails or
reports errors. Anyway I understand that this behavior is required by
the "+C" option.
Thanks anyway,
David Bucciarelli
