POV-Ray : Newsgroups : povray.beta-test.binaries : isosurface contained_by or evaluation problem Server Time
19 May 2024 09:35:43 EDT (-0400)
  isosurface contained_by or evaluation problem (Message 1 to 10 of 10)
Subject: isosurface contained_by or evaluation problem
Date: 6 Oct 2001 04:33:11
Message: <3bbec1c7@news.povray.org>
Hello,
I notice a problem with contained_by or an evaluation problem
with a very regular isosurface of deg 6 ( x^n+y^2+z^2-1.5).
With n = 4 and a contained_by box <-3,3> the surface is present.
With n = 6 the surface disappears completely .
With n= 6 and a smaller container box<-2,2>, the surface appears
Download 'deg4_cont.bmp.dat' (57 KB) Download 'deg6_contbig.bmp.dat' (57 KB) Download 'test02.pov.txt' (3 KB) Download 'de6_contb2.bmp.dat' (57 KB)
Subject: Re: isosurface contained_by or evaluation problem
Date: 6 Oct 2001 04:35:42
Message: <3bbec25e@news.povray.org>
Could you please post images in PNG format, not BMP?
  PNGs are much smaller and better supported accross platforms/newsreaders.
Date: 6 Oct 2001 04:41:22
Message: <3bbec3b2@news.povray.org>
The evaluation version is beta 4
Date: 6 Oct 2001 06:00:55
Message: <3bbed657@news.povray.org>
This seems to be just another max_gradient affair. If you set it to 160 (80
was not enough) the Iso will show up. My testrender is now at 80% and
everything seems to be okay.
If you narrow the contained_by-object, the samples Pov takes with a given
max_gradient and accuracy will be not that far apart and this will lead to a
more accurate isosurface. For this it's always a good idea to bound the iso
as narrow as possible.
Marc-Hendrik
Date: 6 Oct 2001 08:57:18
Message: <z9IXyLAY9vv7Ew5H@econym.demon.co.uk>
Wasn't it Pierre Pruvost who wrote:
>Hello,
The actual gradient of a polynomial function in the order of n*x^(n-1).
So the sort of gradients that you'll encounter at the edges of your
container change something like this:
n=4, container <-3,3>, gradient 4*3^3 = 36
n=6, container <-3,3>, gradient 6*3^5 = 1458
n=6, container <-2,2>, gradient 6*2^5 = 192
Because your max_gradient is set *way* too low, the solver simply
evaluates the function at the edges of the container. It believes the
value of max_gradient that you've given it and knows that the nearest
surface point can't be closer than
 (calculated_value - threshold) / max_gradient
so there are "obviously" no surface points within the box.
You happen to be getting away with max_gradient = 40 in the <-2,2> case
because the solver determines that it needs to look for the surface
somewhere in the middle, and once it gets near the middle of the box the
gradients are much lower.
Mike Williams
Gentleman of Leisure
Date: 6 Oct 2001 09:22:31
Message: <3BBF0674.D0444328@gmx.de>
Ahhh!
Sometimes you don't see the obvious even if it's right in front of you...
(see also p.b.i.)
So it's important to say that the max_gradient value should be larger than
the gradient *everywhere* in the container, not only near the actual
surface.
Date: 6 Oct 2001 10:55:26
Message: <3BBF1CB7.79699457@pacbell.net>
Actually I prefer jpgs. I have to open png's in a seperate program to
view them.
Ken Tyler
Date: 7 Oct 2001 00:36:10
Message: <h$izSBAxt9v7EwaK@econym.demon.co.uk>
>surface.
If the solver knew where the actual surface was, then it wouldn't need
to be told the max_gradient.
Note also that there are some functions that have regions where the
actual gradient is infinite, but you can often get away with setting a
smaller value for max_gradient.
Mike Williams
Date: 7 Oct 2001 04:48:15
Message: <3BC017B2.DEBF4A87@gmx.de>
I know, but it could be changed to do additional steps (meaning higher
max_gradient) if the evaluated function values differ very much from the
threshold value.  Alternatively it could also generate a warning if the
gradient is obviously higher than max_gradient and if there can't be a
visible surface with the specified max_gradient (like in this case)
Although if the gradient is infinite 'across the threshold value' like
when you use a checker pattern etc. with threshold 0.5 you will most
likely not be able to totally avoid artefacts.
Date: 7 Oct 2001 15:39:48
Message: <3bc0af84@news.povray.org>
Thanks !
>Mike Williams
