POV-Ray : Newsgroups : povray.beta-test.binaries : Vanish/Ghost/Killer bug Server Time
4 Jul 2025 00:43:40 EDT (-0400)
  Vanish/Ghost/Killer bug (Message 1 to 4 of 4)
Subject: Vanish/Ghost/Killer bug
Date: 15 Apr 2002 14:44:26
Message: <3CBB1FA0.9C372A03@gmx.de>
This is the minimum scene-file Thorsten Froehlich requested to
check the bug. When tracing with focal-blur, objects get
cut in half or vanish, depending on which object you use
to be translated by vnormalize(<0,0,0>).
Interesting side-effect:
The "cut" is "blurred focally", or at least it appears so.
Tim Nikias
Email: Tim### [at] gmxde
Download 'us-ascii' (2 KB)
Subject: Re: Vanish/Ghost/Killer bug
Date: 15 Apr 2002 15:23:10
Message: <3cbb289d@news.povray.org>
  Oh... well, if you use vstr() with vnormalize(<0,0,0>), you will se it
returns a vector <nan,nan,nan>. If you look also at the docs, the
description for vnormalize() "criptically" states that "vnormalize(<0,0,0>)
will not give a usefull result". This sounds more like an undesired side
effect than a bug... and from the docs wording I can supose there is no
easy solution for the problem. Note this sentence was not on the 3.1 docs,
so I suspect it was discussed on a previous bug report...
  Anyhow, if your using vnormalize inside loops, you can test for the
"special case" to replace it with the apropiate value (if it makes sense at
all).
  Hope this helps!
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 15 Apr 2002 21:59:55
Message: <3cbb859a@news.povray.org>
  This is a case where there's no simple solution, even though it could
look like that at first glance.
  Some people think that vnormalize(<0,0,0>) should return <0,0,0>.
That's *not* a good solution because it breaks the very definition of
vnormalize. vnormalize is defined to always return a vector of lenght 1,
which <0,0,0> is not. If you trust that it always returns a vector of
that length but there's a special case where it doesn't, then you can't
trust it anymore.
  The best solution is, of course, that POV-Ray would issue an error if
a 0-vector is normalized (because it can't). Getting a clear error message
is always better than getting a weird result.
Date: 16 Apr 2002 00:00:48
Message: <3cbba1f0@news.povray.org>
I most definitely agree.
