POV-Ray : Newsgroups : povray.animations : Dominoes Server Time
16 Jun 2026 02:23:42 EDT (-0400)
  Dominoes (Message 1 to 10 of 16)
Subject: Dominoes
Date: 27 Apr 2026 17:15:00
Message: <web.69efd1a1dcb79583909ee801f712fc00@news.povray.org>
3oo plus animated dominoes. Made the dominoes a while back and gave up animating
them because placing them wasn't very much FUN. I started back up because making
small sets that create simple shapes was! If you create a group of these sets
then you can place a lot of dominoes fairly quickly.
 I tried to get the video size down small enough to attach here, but couldn't.
So I put it on YouTube. Hope you enjoy it.
Video link
https://youtu.be/gJtzmqIOLw8
Have Fun :)
Subject: Re: Dominoes
Date: 29 Apr 2026 18:15:00
Message: <web.69f28210cea3e23e993716b9199194f2@news.povray.org>
"Leroy" <whe### [at] gmailcom> wrote:
> Video link
> Have Fun :)
I too like to simulate and render dominoes inside the bullet physics playground,
see:
  https://youtu.be/B7EtmXFeUE0
Happy POVing!
Download 'screenshot_20260430_000330.png' (227 KB)
Preview of image 'screenshot_20260430_000330.png'
Date: 30 Apr 2026 03:35:00
Message: <web.69f305fdcea3e23ef07af049d49cbb40@news.povray.org>
> > Video link
> > Have Fun :)
> see:
> Happy POVing!
And did he work on this BPP terminal?
Date: 30 Apr 2026 15:00:00
Message: <web.69f3a63dcea3e23eb165b1ecf712fc00@news.povray.org>
> > Video link
> > Have Fun :)
> see:
> Happy POVing!
Cool! The music was a good touch. I should have put some sound on mine, but I
got lazy. What I thought of doing is make the sound of a domino hitting the next
and sliding down. Then use that sound in sync with the dominoes movement. Maybe
one of these days.
 I was wondering how you place the dominoes. I use a spline for placement. I
have my dominoes placed 2 pov units apart. That because I don't use true physics
to move the dominoes. With them spaced evenly I could simplify the movement
function.
 Noticed that your dominoes have different spacing, they got tighter toward the
center. Your physics engine did a good job of dropping them. I also like the
wiggle the engine gave to the already down dominoes.
Have Fun!
Date: 1 May 2026 06:20:00
Message: <web.69f47d99cea3e23e993716b9199194f2@news.povray.org>
Archimedean spiral calculation is used to create the control points [1]:
  [... line 47]:
  local angle = (i - 1) * 0.09
  local radius = 5 + angle * 0.95
  cp = {
    x = math.cos(angle) * radius,
    y = y_pos,
    z = math.sin(angle) * radius,
The control points are then fed to the Catmull-Rom spline function [2] with the
tension parameter set to 0.5.
> center.
I would like to have equal spacing between the dominoes, but I do not know how
to calculate that, do you have an idea?
I have been experimenting with different parameters for the friction,
restitution, linear and angular damping of the dominoes, currently using:
  friction = 0.01
  restitution = 0.01
  damp_lin = 0.5
  damp_ang = 0.01
Kind regards,
koppi
[1]
https://github.com/bullet-physics-playground/bpp/blob/b558bdf8e8ab23a1438d0162d40c7f0029eb3efd/demo/basic/11-domino.lua
[2]
https://github.com/bullet-physics-playground/bpp/blob/b558bdf8e8ab23a1438d0162d40c7f0029eb3efd/demo/module/spline.lua#L
134
Date: 1 May 2026 06:50:00
Message: <web.69f48436cea3e23ed1d09a9825979125@news.povray.org>
Luckily, I have played a lot with spirals, and needed to address this issue when
implementing Marschner's wood texture.
Here's a little scene that calculates the arc length along the spiral and uses
that to control a pigment {function {}}.
Hopefully you can see how that's all daisy-chained together and can use that to
place your dominoes.
- Bill
Download 'spiralpattern.pov.txt' (4 KB)
Date: 1 May 2026 08:30:00
Message: <web.69f49bfecea3e23e993716b9199194f2@news.povray.org>
Oh Bill, thank's for the inspiration!
I just added the arc_length and solve_theta_for_arc functions to my Lua code:
https://github.com/bullet-physics-playground/bpp/commit/2b52508742249fe96dc48f6aa3b2ef5ab3867bd0
It works! - see attached screenshot, jippie!
Download 'screenshot_20260501_142400.png' (250 KB)
Preview of image 'screenshot_20260501_142400.png'
Date: 1 May 2026 09:20:00
Message: <web.69f4a822cea3e23e993716b9199194f2@news.povray.org>
Video link
https://youtu.be/coJWp8DlpFU
Date: 1 May 2026 11:00:00
Message: <web.69f4bec8cea3e23eda82d88b25979125@news.povray.org>
Excellent.
I see that the dominoes are positioned at an angle, and that spot around the
270-degree mark has a marked discontinuity, and so those dominoes get shot out.
Can you position the dominoes so that they are perpendicular to the normal of
the spiral?  Or is the imperfectness of their placement a "feature" for more
realism?
- BW
Date: 1 May 2026 12:10:00
Message: <web.69f4cfeecea3e23e993716b9199194f2@news.povray.org>
> realism?
I just have fixed the domino orientation along the spiral as you have suggested,
for the changes see:
https://github.com/bullet-physics-playground/bpp/commit/e37fa0de7a0b94d2233428c690e93d29322b2154
Kind regards,
koppi
Download 'screenshot_20260501_180139.png' (264 KB)
Preview of image 'screenshot_20260501_180139.png'
