POV-Ray : Newsgroups : povray.animations : HELP! problem with CSG syntax Server Time
27 Jul 2024 14:25:54 EDT (-0400)
  HELP! problem with CSG syntax (Message 1 to 3 of 3)
Subject: HELP! problem with CSG syntax
Date: 11 May 2020 22:15:00
Message: <web.5eba04fc45e5c9e8ecfb76150@news.povray.org>
I consider myself an advanced POV user but this one is mystifies me. I am trying
a simple model of a butterfly wing movement in a sort (12 frames, 3/4 sec)
animation. This is my code:
//rapid downstroke
#declare startclock=0;
#declare endclock =4;
#declare localclock=clock-startclock;
#if(clock>startclock & clock<=endclock) union { { Rightwing rotate
<0,0,60-14*localclock>} {Leftwing rotate<0,0,-(60-14*localclock)>}
rotate<-30,-30,0> translate <30,-(55-localclock), 50> }  #end
//slower return up
#declare startclock=endclock;
#declare endcolck=startclock+8;
#if( clock>startclock & clock <=endclock) union { { Rightwing rotate<
0,0,7.5*localclock>} {Leftwing rotate<0,0,-7.5*localclock>}  rotate<-20,-35,0>
translate <10,-(54+0.5*localclock), 100>  }  #end
Povray refuses to accept the first #if statement: "No matching } in 'union', {
found instead" What is wrong with the union syntax?
More puzzling, if I comment out the first #if statement, it accepts the second
one and proceeds to rendering, even though the union syntax is EXACTLY the same.
What am I doing wrong?
Thanks for any help
Constantin
Subject: Re: HELP! problem with CSG syntax
Date: 12 May 2020 01:15:00
Message: <web.5eba309a515d007f60e0cc3d0@news.povray.org>
You are missing the 'object' keyword:
> //rapid downstroke
                                             here^
                 and here^
> //slower return up
                                           and here^
              and here^
The second #if is never satisfied, so POV-Ray never gets to flag it as a syntax
error.
Date: 17 May 2020 20:50:01
Message: <web.5ec1dabe515d007fecfb76150@news.povray.org>
You were absolutely right, that's all I needed to do. Rusty skills, I hadn't
used POV for years.
Many thanks!
Constantin
