POV-Ray : Newsgroups : povray.animations : Dodge on povray Server Time
2 May 2024 05:06:56 EDT (-0400)
  Dodge on povray (Message 1 to 2 of 2)
Subject: Dodge on povray
Date: 1 Jun 2018 14:45:00
Message: <web.5b1192ac641bd2fef6e6d4890@news.povray.org>
Hi !
I'm sorry for my English level...
I'm a student in the media production field and I have to create an animation
which consist of animate balls. For the moment, I just want to make a video
where two balls are about to collide, but one of the balls dodge the other.
The problem is that I can't do that.
I try to get the different between the 2 balls position. The problem is that the
result value's is sometimes 0, so in my equation, it don't work...
Have you some suggestions for me please ?
Thank's !
Here is the program :
#version 3.7;
#include "textures.inc"
#declare BARRE = cylinder {<0, 0, 0> <0, 10, 0> 0.05 }
#declare Epaisseur=1;
//Formes
#declare BILLE = sphere { <0, 0, 0> Epaisseur };
//Materiaux
#declare ROUGE = material { texture { pigment { Red } } };
#declare VERT = material { texture { pigment { Green } } };
#declare BLEU = material { texture { pigment { Blue } } };
//Habllage
#declare BARREX = object { BARRE material { ROUGE } };
#declare BARREY = object { BARRE material { VERT } };
#declare BARREZ = object { BARRE material { BLEU } };
#declare BILLER = object { BILLE material { ROUGE } };
#declare BILLEG = object { BILLE material { VERT } };
//Assemblage
#declare REPERE = union
    object { BARREX rotate <0, 0, -90> }
    object { BARREY }
    object { BARREZ rotate <90, 0, 0> }
//Scene
plane {y,0 pigment {checker pigment {Black}, pigment {White}  } }
object { REPERE }
//Annimation
#declare POS_G = <0, 1, -12+20*clock>;
#declare POS_R = <-10+20*clock, 1, -2>;
#declare Diff = POS_G.x - POS_R.x;
#if ( abs(Diff.x) < 4*Epaisseur )
    #declare POS_G = <POS_G.x+(1/Diff.x+1), POS_G.y, POS_G.z>;
// Mise en scene
object { BILLER translate POS_R}
object { BILLEG translate POS_G}
    location <0, 10, 5>
    look_at <0, 0, 0>
    angle 90
light_source {
    <1, 8, 1>
    White*0.7
Subject: Re: Dodge on povray
Date: 1 Jun 2018 17:01:38
Message: <5b11b432$1@news.povray.org>
On 06/01/2018 02:40 PM, Saxoalex wrote:
> Hi !
> //Annimation
try
#declare Diff = vlength(POS_G - POS_R);
#debug concat("Longueur = ", str(Diff,0,2), "\n")
dik
Rendered 328976 of 330000 (99%)
