POV-Ray : Newsgroups : povray.animations : Shed version 2 Server Time
28 Mar 2024 07:27:26 EDT (-0400)
  Shed version 2 (Message 1 to 10 of 33)
Subject: Shed version 2
Date: 12 Feb 2017 12:25:00
Message: <web.58a09968c40ea84c5f9209890@news.povray.org>
using windows Movie Maker, because I can't afford to buy anything at this time.
0.5 seconds on each still frame, 15 frames in 0.9 seconds for the tilt-up of the
walls
the tilt-up is much smoother than I thought it would be.
https://youtu.be/J1R3EnIDCgc
you can see version 1 in the thread /animations/grouping objects for transforms
Subject: Re: Shed version 2
Date: 12 Feb 2017 14:40:01
Message: <web.58a0b9d9e97123ee9c5d6c810@news.povray.org>
> walls
Looks good! Sure helps add fluidity having movement... hey, a thought... which
you seemed to be hinting at already. Camera view moving around from wall to wall
would give it less slideshow feel too.
Animation doesn't always need a high frame rate anyway, cartoons often use low
frame counts; so 12 per second can be okay. Yours was 16.667 per second for
those fastest parts.
Hmm, on that note... if you do move the camera all the way around it'll require
upping the frame count per second since that's a lot of movement.
Maybe just going from first position to last position (walls to roof) from start
to end could be okay...?
Date: 12 Feb 2017 15:23:50
Message: <58a0c456$1@news.povray.org>
And a slight movement in the sky would help with a sense of "time going by".
Regards
Date: 12 Feb 2017 16:50:01
Message: <web.58a0d86de97123ee9c5d6c810@news.povray.org>
Yeah, good idea, makes me think time lapse photography to get a real sense of
actual build time. Although sunrise to sunset would indicate a slow build for
what's there right now, so maybe either sunrise to noon or noon to sunset until
more complete.
Or am I overthinking this?  ;)
Date: 12 Feb 2017 18:47:04
Message: <58a0f3f8$1@news.povray.org>
> more complete.
No, dawn to dusk would be my preference.
A good days work. :-)
Regards
Date: 13 Feb 2017 02:55:59
Message: <58a1668f$1@news.povray.org>
>>>> thought...
>>> going by".
>> sense of
>> build for
>> sunset until
>> more complete.
With a pause at noon surely? The man needs to eat! ;-)
Date: 13 Feb 2017 03:37:33
Message: <58a1704d$1@news.povray.org>
>>>>> thought...
>>>> going by".
>>> sense of
>>> build for
>>> sunset until
>>> more complete.
Only mad dogs and Englishmen go out in the midday sun. Sorry. :-)
Regards
Date: 13 Feb 2017 07:35:36
Message: <58a1a818$1@news.povray.org>
>>>>>> thought...
>>>>> going by".
>>>> sense of
>>>> build for
>>>> sunset until
>>>> more complete.
Nah! in the UK it is always drizzling... :-)
[or was, before climate change...]
Date: 13 Feb 2017 08:18:13
Message: <58a1b215$1@news.povray.org>
You should know. The Netherlands often gets our leftover weather. ;-)
Regards
Date: 13 Feb 2017 09:19:31
Message: <58a1c073$1@news.povray.org>
Am 2017-02-13 08:18, also sprach Stephen:
Netherlands second!
https://www.youtube.com/watch?v=ELD2AwFN9Nc
dik
