POV-Ray : Newsgroups : povray.animations : alternating objects depending on Z value of spline vector animation Server Time
19 May 2024 21:56:21 EDT (-0400)
  alternating objects depending on Z value of spline vector animation (Message 1 to 5 of 5)
Subject: alternating objects depending on Z value of spline vector animation
Date: 19 Sep 2010 19:05:01
Message: <web.4c9695f2878a51c8fdfcf7500@news.povray.org>
Hello!
I'm controlling the location of a object by the use of a spline (see code
below).
I'm only rendering the exact frames given in the spline. That's why the control
points don't matter to me.
Initial_Frame=1
Final_Frame=12
Initial_Clock=0
Final_Clock=11
I need to switch to a different object when the Z-Value reaches a certain limit.
(See fake code line below).
a) How can something like this be done?
b) is there a easier more elegant way to switch location of an object than
"mis-using" a spline?
Thanks!
#### code ####
#declare TARGET=
cylinder {<0,0,0><0,0,400>,200 pigment {rgb <0,1,0>} finish {ambient 0.5}}
#declare TARGET2=
cylinder {<0,0,0><0,0,600>,200 pigment {rgb <1,0,0>} finish {ambient 0.5}}
#declare Spline_1 =
  spline {
   natural_spline
  -1, <-0,0,0>,//control point
   0, <-20000,-10000,1000>,//start point
   1, <-20000,-9000,1000>,
   2, <-20000,-8000,1000>,
   3, <-20000,-7000,1000>
   4, <-20000,-6000,1000>,
   5, <-20000,-5000,1000>,
   6, <-20000,-10000,2000>,
   7, <-20000,-9000,2000>,
   8, <-20000,-8000,2000>,
   9, <-20000,-7000,2000>
 10, <-20000,-6000,2000>,
 11, <-20000,-5000,2000>,
 12, <0,0,0>//control point
#if (Z-value of Spline_1(clock) is less or equal 1000 ) // Is something like
this possible? If yes, how?
 object {TARGET translate Spline_1(clock)}
#else
 object {TARGET2 translate Spline_1(clock)}
Subject: Re: alternating objects depending on Z value of spline vector animation
Date: 19 Sep 2010 23:30:01
Message: <web.4c96d49478c97e55d939a6800@news.povray.org>
> below).
> #else
> #end
I think this might be what you're looking for.
#if (Spline_1(clock).z <= 1000)
Date: 20 Sep 2010 07:20:00
Message: <web.4c9742d378c97e55fdfcf7500@news.povray.org>
> > #else
> > #end
Thanks! Somehow I knew stuff like this is easy in SDL. At least for someone who
knows what he is doing :-)
Cheers!
Andi
Date: 20 Sep 2010 12:35:00
Message: <web.4c978cd878c97e55d939a6800@news.povray.org>
> > > #else
> > > #end
YW! Heh, if only I knew what I was doing in POV-Ray most the time. I seem to
remember a fraction of what I learn.
Date: 20 Sep 2010 16:55:01
Message: <web.4c97c91d78c97e55196b08580@news.povray.org>
> > who knows what he is doing :-)
> Bob
Ditto. I seem to always be 'reinventing the wheel'--forgetting how to do stuff
that I've already figured out. Lately, I've been creating shortcuts to my
scenes, with different titles, just to remind me of some small discovery I've
made in the code. My memory ain't what it used to be...
Ken
