Hi all,
I would like to animat a height-field, like an erupting surface or water.
I have managed to get the static height-field.
height_field{png "heightField_1.png" smooth
texture{
pigment{
image_map{
png "teture.png"
rotate x*90 // lay X-Y image map down onto X-Z height
But I dont know how to tell pov-ray to loop
over 300 height-fields;
with every *.png beeing a single frame: heightField_1.png ...
Do I have to code a fileName-variable like:
#while (Count < 300)
#declare fileName=concat("heightField_", str(A,1,1), ".png")
#declare Count=Count+1;
but how to tell pov-ray to render automatically and save the frames?
Or is there an easy way by using the clock variable?
thanx in advance!!!
Bent
Hi Bent,
You need to have your image maps numbered sequentially, tied to the
frame numbers of your animation. Then use frame_number, something like
(Note it is not tested)
texture{
pigment{
image_map{
png concat("teture",
str(frame_number,-1,0),".png")
height
You should read the help 3.2.1.7.3 String Functions
To get the correct values for the string padding.
Also for fault finding add a #debug statement like (Not Tested)
#debug concat("frame_number = ",frame_number, "/t", "Image =
",str("teture", str(frame_number,-1,0),".png"), "/n")
Read 3.2.2.7.1 Text Message Streams
Regards
"BentLarsen" <nomail@nomail> wrote in message
news:web.485a7b8752ee3a6c70f2ad620@news.povray.org...
> Hi all,
>... snip ...
To animate you need to specify animation options either on the command-line
or in an 'ini' file. In the Windows POV-Ray editor you can specify
command-line options in the input field next to the screen resolution
pull-down at top-left.
I usually use +kfi1 +kff100 in the command-line input field. These will do
the same as the 'ini' file options Initial_Frame=1 and Final_Frame=100. The
POV-Ray scene file will render 100 times and will append the frame number to
the name of the image file generated. If your scene file is called 'MyScene'
and you're generating 'bmp' files then, by default, the first image file
generated will be called 'MyScene001.bmp' etc.
You don't need the #while loop within the scene file.
Within your scene you can then use the frame_number variable to control the
name of the heightfield input file that you want to use and potentially also
the texture file as Stephen described. I think you'll probably want
str(frame_number,-3,0) which would give you 3 digits padded on the left with
zeros.
Chris B.
