POV-Ray : Newsgroups : povray.animations : camera motion Server Time
17 May 2024 17:13:05 EDT (-0400)
  camera motion (Message 1 to 2 of 2)
Subject: camera motion
Date: 29 May 2008 05:55:01
Message: <web.483e7ca0eaa1b6dfbe7bfb550@news.povray.org>
Hi:
All of us know how complex is to move the camera in a soft way in POV... well,
it is complex for me!!!, jajaja
Well, I have seen that some people uses splines to move the camera in a soft and
continous trayectory. But for me it will be interesting to have a program that
allowes you to draw the 3D trajectory by hand and then to write it down into
numbers (coordinates). Probably, to write function pieces would be much better,
but an enough large set of coordinates would be ok aswell.
I suppose I could do something like this by programming in Fortran, but that is
my daily job so I would like to avoid that choice...
Somebody knows about something like this (obviously not Maya or 3Ds, jejeje).
Thanks in advance and go on working
www.enriquesahagun.es
Subject: Re: camera motion
Date: 29 May 2008 07:19:02
Message: <483e9126$1@news.povray.org>
"kike" <dry### [at] hotmailcom> wrote in message
news:web.483e7ca0eaa1b6dfbe7bfb550@news.povray.org...
> Hi:
> well,
> soft and
> that
> into
> better,
> that is
> jejeje).
Hi. Not sure if this is the sort of thing you're after, one approach I've
investigated (for other purposes) is to use Inkscape to draw a path.
Inkscape saves 2D vector graphics as SVG files by default, but has an option
to save as a POV-Ray prism object which gives you the 2D coordinates of a
bezier spline. Bezier splines have 4 points per line segment with points 1
and 4 being the points on the curve and points 2 and 3 being control points.
Although the POV-Ray spline function doesn't support bezier splines,
Inkscape writes the coordinates in sets of 4 per line that are all aligned
properly and, for a continuous curve, point 4 on one line equals point 1 on
the next line, so you can easily extract all of the points on the curve by
simply taking the first vector from each line.
Sounds a bit complicated, but I think you should be able to generate an
orthographic plan from POV-Ray, load it as a bitmap into Inkscape. Scale
appropriately, then draw a 2D path on the plan that you can save as a
POV-Ray prism object. Just pick up all of the points defined for the curve
by selecting the first vector from each line using columnar select in a text
editor.  You can then 'edit in' a third coordinate (easy if you want a
constant height) and a value setting to build the points into a spline
definition and, hey presto, you've got a path for the camera to follow.
Note. By not using the control points, the shape of the curved segments
between the points won't be exactly the same as in Inkscape, but if you use
enough points for the path in Inkscape, then the resulting spline should
closely follow the line. This is easy to do in Inkscape because there's a
little icon that lets you insert new nodes between all selected nodes, so
you can create a nice smooth path using a small number of points and their
control points, then add a bunch of intermediary nodes before saving as a
prism.
Note 2. I haven't tried out exactly this approach as my objective was
different to yours, but I regularly use prism objects generated using
Inkscape and have experimented with using points for different spline types,
so I'm pretty sure this will work. If this approach interests you I'd be
happy to do a couple more experiments to test it out.
Chris B.
