POV-Ray : Newsgroups : povray.animations : PNG to AVI with MonkeyJam Server Time: 16 May 2008 05:10:03 GMT
  PNG to AVI with MonkeyJam (Message 1 to 2 of 2)
Subject: PNG to AVI with MonkeyJam
Date: 23 Feb 2008 13:30:01
Message: <web.47c01eb8578137bf5116a38d0@news.povray.org>
Hi
I've been looking around for a simple, free PNG to AVI (xvid) converter for
Windows for a long time, without much luck. But just now I stumbled upon
MonkeyJam - http://www.giantscreamingrobotmonkeys.com/monkeyjam/index.html
It is a utility designed for stop motion animation, but it works perfectly
for POV-Ray use. Just change "Hold" to 1 when you import your frames.
Without trying it more than a couple of times I belive it inputs any image
format (PNG, BMP, JPG, TIF etc), as well as sound, and outputs to any AVI codec
you have installed (DIVX, XVID, WMV etc).
I didn't find it in the links collection, and it only gave one hit in the
newsgroups, which tells me a lot of people might not know of this excellent
program.
Just a small notice ;)
-Peter
Subject: Re: PNG to AVI with MonkeyJam
Date: 28 Feb 2008 11:43:29
Message: <47c69e61@news.povray.org>
> for
Just another small recommendation I thought I'd share, I use AVIsynth to
create an uncompressed AVI stream from PNGs.
For example, just make an avisynth script called PNG.avs (or whatever) that
contains:
video = ImageSource("frame%03d.png", start=1, end=600, fps=25,pixel_type =
"rgb24")
return video
Then, you can just use some normal encoder (most accept .avs avisynth files
as input) to create your compressed video.  I use Xvid4PSP because it can
create the 1080p h264 files that play on the PS3.  Works a treat and allows
a lot of flexibility.
Copyright 1991-2004 POV-Team™
